Home » Eclipse Projects » NatTable » Excel Export with .xlsx
Excel Export with .xlsx [message #1772718] Thu, 14 September 2017 09:43 Go to next message
Naveen Sabapathy is currently offline Naveen SabapathyFriend
Member
I have implemented the export to excel functionality. It supports .xls format.
Do we have the functionality of exporting it to excel with .xlsx format?
if its not available, whats the simple workaround?
Re: Excel Export with .xlsx [message #1772743 is a reply to message #1772718] Thu, 14 September 2017 15:16 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
Use the Apache POI extension and see what it can do for you
Re: Excel Export with .xlsx [message #1780176 is a reply to message #1772743] Thu, 18 January 2018 12:17 Go to previous messageGo to next message
Member
Dirk Fauth wrote on Thu, 14 September 2017 17:16
I could not able to find anything related to XSSF in complete apache poi extension.
So, does that means it doesn't support the .xlsx export?
Are there any other way to achieve that?
Re: Excel Export with .xlsx [message #1780181 is a reply to message #1780176] Thu, 18 January 2018 13:02 Go to previous message
I see, IIRC there is no XSSF export support in our extension because of issues with the OSGi-ification of the XSSF stuff from Apache POI.
If you need that you will need to see how to get the library in your runtime and implement an exporter that creates an export using XSSF.
Previous Topic:Auto resize column by double clicking
Next Topic:Help with overriding grid line rendering methods
Current Time: Sun Aug 25 07:15:54 GMT 2019
Powered by FUDForum. Page generated in 0.01608 seconds
