Re: Eclipse can't find header files [message #1772770 is a reply to message #1772649] |
Fri, 15 September 2017 03:11 |
David Vavra Messages: 1426 Registered: October 2012 |
I've tried this with directories from my own system using both
Project --> Properties --> C/C++ General --> Paths and Symbols --> Includes
Project --> Properties --> C/C++ General --> Preprocessor Include Paths, Macros etc. --> CDT User Settings Entries
with no problems.
Be sure that the full path used actually contains the include starting with api/ ....
Also, make sure it was added under C++ with the proper configuration.
The paths added using Paths and Symbols should be listed under
Project --> Properties --> C/C++ General --> Preprocessor Include Paths, Macros etc. --> CDT Managed Build Settings Entries
You may need to rebuild the index after adding a path.
Project --> C/C++ Index --> Rebuild
FUDForum. Page generated in 0.03055 seconds
