Home » Modeling » TMF (Xtext) » Use of proposalprovider for content-assist
Use of proposalprovider for content-assist [message #1772235] Thu, 07 September 2017 04:02 Go to next message
Kaushal Patel is currently offline Kaushal PatelFriend
Member
Hello Experts,
I am trying to implement content-assist in pathexpression using cross-reference within double quotes.
I read these articles to solve reference problems and pathexpression implementation.
https://christiandietrich.wordpress.com/2015/03/19/xtext-and-strings-as-cross-references/
https://christiandietrich.wordpress.com/2013/05/18/xtext-and-dot-expressions/
I am writing grammar for yang language. While writing my yang file in new eclipse application I am getting error in schemanodeidentifier.
This is what I am trying to implement.
submodule "NAME"{
	container "N"{
		leaf-list "A"{
			leaf "M"{
				list "E";
	augment "/N/A/M/E";
I am getting this error:
Couldn't resolve reference to SchemaNode '"/N/A/M/E"'.
I am not getting error when I write like this:
augment /"N"/"A"/"M"/"E";
This is my grammar.
YangFile:
	Module|
	SubModule
Module:
	"module" name=STRINGARG
	(statements+=Statement)*
SubModule:
	"submodule" name =STRINGARG
Statement:
	  SchemaNode | OtherStatement
SchemaNode :
	DataSchemaNode ;
OtherStatement:
	Augment
DataSchemaNode :
	Container |
	List |
	Leaf |
	LeafList
Container:
	'container' name=STRINGARG (';'|
			(substatements+=DataSchemaNode)
Leaf :
	'leaf' name=STRINGARG (';'|
LeafList:
	'leaf-list' name=STRINGARG (';'|
List:
	'list' name=STRINGARG (';'|
Augment:
	'augment' path=SchemaNodeIdentifier ';'
SchemaNodeIdentifier returns SchemaNodeIdentifier :
	 RootSchemaNodeIdentifier ({SchemaNodeIdentifier.target=current}"/"?(schemanode=[SchemaNode|QNAME]))*
RootSchemaNodeIdentifier returns SchemaNodeIdentifier:
	{RootSchemaNodeIdentifier}isAbsolute?="/"?(schemanode=[SchemaNode|QNAME])
STRINGARG:
	ID|"default"|INT | STRING ;
QNAME:
	(STRINGARG ':')? STRINGARG
I haven't use proposal provider or scope provider.
I am confused that what should I use to achieve my output.
Re: Use of proposalprovider for content-assist [message #1772236 is a reply to message #1772235] Thu, 07 September 2017 04:22 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Use scopeprovider. Content assist itself uses scope provider
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Use of proposalprovider for content-assist [message #1772237 is a reply to message #1772236] Thu, 07 September 2017 04:23 Go to previous messageGo to next message
And
Could not resolve reference is a scoping error
So you need to fix this anyway
And since the whole thing is the reference you don't have any path
Re: Use of proposalprovider for content-assist [message #1772239 is a reply to message #1772237] Thu, 07 September 2017 04:52 Go to previous messageGo to next message
Member
Thanks Chrisitian,
But I have one more confusion,
Is there any difference between SchemaNodeIdentifier or PathExpression?
As per YANG,
AugmentStatement only uses SchemaNodeIdentifier.
Re: Use of proposalprovider for content-assist [message #1772242 is a reply to message #1772239] Thu, 07 September 2017 05:36 Go to previous messageGo to next message
in path expression xxx/yyy/zzz consistst of 3 parts = 3 references
same with augment /"N"/"A"/"M"/"E"
SchemaNode "/N/A/M/E" is one part = 1 reference
Re: Use of proposalprovider for content-assist [message #1772243 is a reply to message #1772242] Thu, 07 September 2017 05:38 Go to previous messageGo to next message
Member
Hi Christian,
I am using your dsl example as a refernce but it shows me error at
EntityRef : Scopes::scopeFor(head.entity.features)
The error is:
The method getEntity() from the type EntityRef refers to the
missing type Object
Re: Use of proposalprovider for content-assist [message #1772244 is a reply to message #1772243] Thu, 07 September 2017 05:42 Go to previous messageGo to next message
this looks like java is not correctly setup in that project.
have a look at java build path in projects properties
Re: Use of proposalprovider for content-assist [message #1772247 is a reply to message #1772242] Thu, 07 September 2017 06:13 Go to previous messageGo to next message
Member
Hi Christian,
Your example works perfectly.
Thanks.
Can I use content-assist within double quotes.
I am using schemanodeidentifier.
Is it possible that i can import single node using content assist within double-quotes.
for example,
augment "N"
then again control+Space in double quotes for another node,
augment "N/A"
same thing again,
augment "N/A/M"
same again,
augment "N/A/M/E"
Like this.
Appreciate your help.
Re: Use of proposalprovider for content-assist [message #1772251 is a reply to message #1772247] Thu, 07 September 2017 06:52 Go to previous messageGo to next message
sorry you ghave to digg into content assis ant prefixes for that yourself
Re: Use of proposalprovider for content-assist [message #1772253 is a reply to message #1772251] Thu, 07 September 2017 07:05 Go to previous messageGo to next message
maybe you can use a iderivedstatecomputer to turn
"a/b/c/d" into actually the same tree structure as "a"/"b"/"c"/"d" would be. use SyntethiclinkingSupport the feed the scoping with the correct proxys. but that wont help with content assist
Re: Use of proposalprovider for content-assist [message #1772254 is a reply to message #1772253] Thu, 07 September 2017 07:12 Go to previous messageGo to next message
Member
Thanks Christian,
If I don't want to implement content-assist in SchemaNodeIdentifier then I can easily implement it using STRINGARG. I can make it STRING.
The main problem is content assist in within double quotes.
Re: Use of proposalprovider for content-assist [message #1772258 is a reply to message #1772254] Thu, 07 September 2017 07:51 Go to previous message
yes but that is your beer
Previous Topic:Xtext and e4 Application
Next Topic:Maven project fails during model validation
Current Time: Thu Oct 21 07:20:02 GMT 2021
Powered by FUDForum. Page generated in 0.01835 seconds
