Home » Eclipse Projects » Sirius » Experimental mode to serialize representations in a different file
Experimental mode to serialize representations in a different file [message #1771661] Tue, 29 August 2017 08:39 Go to next message
Benoit Ries is currently offline Benoit RiesFriend
Member
I have just noticed this in the release notes for 5.0.x:
"Added An experimental mode to serialize representations in a different file is available with system property createRepresentationInSeparateResource=true. That means all new representations will be saved, when this property is enabled, in a separate file with *.srm extension. "
This sounds quite exciting for our product ! :-)
=> What do you mean by "system property" ? Could you please guide me and let me know how to set this property.
many thanks in advance,
BenoƮt
Re: Experimental mode to serialize representations in a different file [message #1771680 is a reply to message #1771661] Tue, 29 August 2017 13:32 Go to previous message
Laurent Fasani is currently offline Laurent FasaniFriend
You can set the system property to true either
* with API: System.setProperty("createLocalRepresentationInSeparateResource", "true")
* or using -DcreateLocalRepresentationInSeparateResource=true in your .ini file or your launch config
regards
Laurent
Laurent Fasani - Obeo
Previous Topic:Open DialectEditor programmatically outside of main editor area
Next Topic:Generate odesign programmatically
Current Time: Sun Jan 24 00:19:33 GMT 2021
Powered by FUDForum. Page generated in 0.01957 seconds
