Home » Eclipse Projects » Sirius » Open DialectEditor programmatically outside of main editor area
Open DialectEditor programmatically outside of main editor area [message #1771657] Tue, 29 August 2017 08:04 Go to next message
M V is currently offline M VFriend
Member
what I want to do:
In my RCP I have project and library based on sirius tree. The User can drag an drop item from the library tree to the project tree. This works fine and was no great problem to build in. So now I want to make the UI more usable. It should looks like this layout:
index.php/fa/30519/0/
After application startup i open my library presentation with the DialectUIManager.
final DialectEditor editor = (DialectEditor) DialectUIManager.INSTANCE.openEditor(siriusSession, description, monitor);
Okay, this work also. But it open it in the editor in part market as org.eclipse.ui.editorss. This it not what I want
index.php/fa/30520/0/
I want to show it in the "Library Part". I can move it manually after open the editor, but how can i tell DialectUIManager the to open it direct there?
I do a lot of google research but i don't found a solution. The only thing I found was a hint Pierre-Charles David
If you need is simply to show the editor outside of the main editor
area, this is possible since Eclipse 4.2 (e4 does not really treat the
main editor area as something special), so you can have your editor
"around" another editor in the middle of other views.
But at this step I stuck.
Thanks for help, code snippets or links to right part of manual.
[Updated on: Tue, 29 August 2017 08:06]
Report message to a moderator
Re: Open DialectEditor programmatically outside of main editor area [message #1771675 is a reply to message #1771657] Tue, 29 August 2017 13:21 Go to previous messageGo to next message
Laurent Fasani is currently offline Laurent FasaniFriend
Hello
Your issue is not specific to Sirius but is related to e4.
I advice you to ask in e4 channel.
I found some tutorial about e4 if it can help: https://eclipsesource.com/blogs/2012/05/10/eclipse-4-final-sprint-part-1-the-e4-application-model/
Laurent
Laurent Fasani - Obeo
Re: Open DialectEditor programmatically outside of main editor area [message #1771679 is a reply to message #1771675] Tue, 29 August 2017 13:31 Go to previous message
Member
Thanks for reply, I will take a look tutorial and ask in the E4 forum.
[Updated on: Tue, 29 August 2017 13:32]
Previous Topic:Changing the size of the drawing canvas
Next Topic:Experimental mode to serialize representations in a different file
Current Time: Sun Sep 20 05:36:35 GMT 2020
Powered by FUDForum. Page generated in 0.02096 seconds
