Home » Eclipse Projects » e(fx)clipse » jetty upgrade problem(classNotFound - java.net.url)
jetty upgrade problem [message #1771211] Wed, 23 August 2017 04:58 Go to next message
hsen paws is currently offline hsen pawsFriend
I am trying to upgrade from jetty6 to jetty9 and getting below error on app start.
Can you please advise, why Jetty is not able to read rt.jar? It is in classpath.
Also how i can enable more logging .
I am using JAVA8, Jetty 9.4.5
 INFO log - Logging initialized @2562ms to org.eclipse.jetty.util.log.Slf4jLog
 INFO ContextRepositorySelector - Registering org.apache.log4j.Hierarchy@7586beff for context startJarLoader@4e7dc304
 INFO Server - jetty-9.4.5.v20170502
 INFO AbstractNCSARequestLog - Opened C:\myhome\jetty\jetty-bb\instance-bulsim\logs\request.log.2017_08_23
 INFO ScanningAppProvider - Deployment monitor [file:///C:/myhome/jetty/jetty-bb/instance-bulsim/contexts/] at interval 1
 INFO IndividualTimeoutUserCache - IndividualTimeoutUserCache initalised with timeout [10] minutes
 INFO indoniSybDriver - Registered com.bmh.gunsulting.indoni.sybase.indoniSybDriver[com.sybase.jdbc4.jdbc.SybDriver@25df00a0]
 INFO DatabaseLoginRealm - New realm <Bulk Payment Service> @ jdbc:indoni-sybase:Tds:bd_syb_BSDEV1.macbank:20003
 INFO ContextRepositorySelector - Created org.apache.log4j.Hierarchy@5a37d3ed from file:/C:/myhome/jetty/jetty-bb/instance-bulsim/resources/log4j.prop
erties for context WebAppClassLoader=1188401255@46d59067
 INFO AnnotationConfiguration - Scanning elapsed time=2484ms
 WARN WebAppContext - Failed startup of context o.e.j.w.WebAppContext@5db6b9cd{/trillion-ballarat,file:///C:/myhome/jetty/jetty-bb/instance-bulsim/work
/jetty-trillion-1.0.0-SNAPSHOT.war-_trillion-ballarat-any-/webapp/,UNAVAILABLE}{/trillion-1.0.0-SNAPSHOT.war}
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
        at java.lang.reflect.Method.invoke(Method.java:491)
        at org.eclipse.jetty.webapp.IterativeDescriptorProcessor.visit(IterativeDescriptorProcessor.java:83)
        at org.eclipse.jetty.webapp.IterativeDescriptorProcessor.process(IterativeDescriptorProcessor.java:70)
        at org.eclipse.jetty.webapp.MetaData.resolve(MetaData.java:408)
        at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1461)
        at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:785)
        at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:261)
        at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:545)
        at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
        at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:41)
        at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:188)
        at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:502)
        at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:150)
        at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:180)
        at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:453)
        at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:64)
        at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:610)
        at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:529)
        at org.eclipse.jetty.util.Scanner.scan(Scanner.java:392)
        at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
        at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:150)
        at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:564)
        at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:239)
        at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:131)
        at org.eclipse.jetty.server.Server.start(Server.java:452)
        at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:113)
        at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:113)
        at org.eclipse.jetty.server.Server.doStart(Server.java:419)
        at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1511)
        at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1438)
        at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1437)
        at org.eclipse.jetty.start.Main.invokeMain(Main.java:221)
        at org.eclipse.jetty.start.Main.start(Main.java:499)
        at org.eclipse.jetty.start.Main.main(Main.java:78)
Caused by: java.lang.ClassNotFoundException: java.net.url
        at java.net.URLClassLoader$1.run(URLClassLoader.java:365)
        at java.net.URLClassLoader$1.run(URLClassLoader.java:354)
        at java.net.URLClassLoader.findClass(URLClassLoader.java:353)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:423)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
        at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:560)
        at org.eclipse.jetty.server.handler.ContextHandler.loadClass(ContextHandler.java:1735)
        at org.eclipse.jetty.plus.webapp.PlusDescriptorProcessor.visitResourceRef(PlusDescriptorProcessor.java:252)
        ... 46 more
 INFO Server - Started @7722ms
Re: jetty upgrade problem [message #1771324 is a reply to message #1771211] Thu, 24 August 2017 05:58 Go to previous message
Thomas Schindl is currently offline Thomas SchindlFriend
Please ask at the jetty forum
Previous Topic:Does anyone test e(fx)clipse applications?
Next Topic:@ContextValue problem
Current Time: Thu Mar 30 19:11:56 GMT 2023
Powered by FUDForum. Page generated in 0.01901 seconds
