building the xtext project with the maven build with other java projects [message #1771030] |
Mon, 21 August 2017 11:26 |
I am using xtext 2.12.0 I have checked on the net. I made few changes to the existing parent pom.xml. I see that the grammarUri has to be changed to the platformURi in the mwe2 file. In 2.12.0 I did not find this kind of a structure to fill in the path as it uses the rootpath.
I also want to know if any documentation is available for this scenario for xtext 2.12 version.
Re: building the xtext project with the maven build with other java projects [message #1771257 is a reply to message #1771089] |
Wed, 23 August 2017 12:53 |
I have configured my maven poms and it is working. But my problem I would like to generate the files in a particular path in a project. Also I want to pick my dsl file in the project from a different destination other than src. I would like to know how I can generate the files in different paths.
I have 4 generators seperately for each type of generation. Like from a single model I am generating, XML,HTML, Java, Javascipt, SQL and also Groovy.
Now i want to generate each type of file in different package respectively in an existing project. I have used dependency injection for the generators.
I would like to know where I can alter the generation of files in the structure of my existing project.
Thanks in advance,
Suprith
[Updated on: Wed, 23 August 2017 12:54] Report message to a moderator
FUDForum. Page generated in 0.03634 seconds
