Home » Modeling » Papyrus » Papyrus class diagram - expression methods(How to create methods with expression as return type)
Papyrus class diagram - expression methods [message #1770967] Sun, 20 August 2017 05:22 Go to next message
patricia narvasa is currently offline patricia narvasaFriend
Can anyone please help me how can I create a class diagram with expression as return type. Please see my example for more details.
*I wanted to have a UML class diagram representation of this method
public Int calculateTotalSale(int num1, int num2)
return num1 + num2;
can anyone help? thank you
Re: Papyrus class diagram - expression methods [message #1771163 is a reply to message #1770967] Tue, 22 August 2017 15:11 Go to previous messageGo to next message
Ansgar Radermacher is currently offline Ansgar RadermacherFriend
You can create an opaque behavior that consists of "return num1+num2;". You can choose for instance Java or C++ as language for this behavior. You can link the UML operation with this method (behavior), but it is not possible to see the implementation within the class diagram.
Papyrus SW designer has some example of classes with opaque behaviors (update-site: http://download.eclipse.org/modeling/mdt/papyrus/components/designer/)
Re: Papyrus class diagram - expression methods [message #1771282 is a reply to message #1771163] Wed, 23 August 2017 16:21 Go to previous message
Thank you Ansgar
Previous Topic:Migration from Neon to Oxygen?
Next Topic:C++ reverse engineer howto
Current Time: Thu Aug 13 11:48:06 GMT 2020
Powered by FUDForum. Page generated in 0.02089 seconds
