SecurityException when I use my modified org.eclipse.xtext to run "Generate Xtext Artifacts& [message #1770942] |
Sat, 19 August 2017 07:02 |
mind calm Messages: 57 Registered: July 2017 |
Member |
I met a problem when i use my modified xtext project to run "generate xtext artifacts" in a .xtext file. For details info please see the SecurityException.JPG, OperationCauseException.JPG and errormessage.txt.
As my test, I use the pure xtext source code instead of my modified xtext code, it also has this problem.
only if I use the original org.eclipse.xtext_*.jar, it works.
The exception message shows "signer information does not match signer information of other classes in the same package". But I don't know where the signer information produced.
Can anybody help me?
Best regards!
by Keep Mind Calm
[Updated on: Sat, 19 August 2017 07:08] Report message to a moderator
FUDForum. Page generated in 0.03378 seconds
