XMI Graphical Manipulation [message #1770734] |
Wed, 16 August 2017 15:32 |
Edouard R. Batot Messages: 100 Registered: March 2015 |
Hi folks,
I have two files (attached) which compose usual RoyalAndLoyalSchool case.
One is the metamodel, the other one an instance (valid).
I would like to edit that XMI instance (to make it conforms with OCL constraints) with a graphical tool AND save it in the same XMI style.
What tool would you recommand ?
I would like to visualize references between objects to follow OCL paths easily.
For now I'm using Notepad++ (so graphical :s) and a home made helper (textual, but very usefull).
Edouard
[Updated on: Wed, 16 August 2017 20:47] Report message to a moderator
Re: XMI Graphical Manipulation [message #1770758 is a reply to message #1770744] |
Wed, 16 August 2017 20:22 |
Ok. I'm gona get a be deeper.
My XMI (.xmi), if you take time to open it, is written as following:
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:RandL="http://de.tuhh.sts.octopus/octopus2emfatic/2006/RandL">
<RandL:ProgramPartner name="" numberOfCustomers="72" deliveredServices="/5 /2" programs="/4"/>
<RandL:Membership currentLevel="/7" card="/8" account="/9" programs="/4" participants="/6/@ref_RandL_Customer.0"/>
<RandL:Service serviceNr="91" description="FDZa" pointsEarned="82" condition="true" pointsBurned="84" partner="/0" transactions="/3" level="/7"/>
<RandL:Burning amount="0.15246516276275457" points="6" account="/9" generatedBy="/2" card="/8">
<date year="65" month="48" day="50"/>
</RandL:Burning>
<RandL:LoyaltyProgram name="" partners="/0" levels="/7" participants="/6/@ref_RandL_Customer.3 /6/@ref_RandL_Customer.0 /6/@ref_RandL_Customer.1 /6/@ref_RandL_Customer.2 /6/@ref_RandL_Customer.4" memberships="/1"/>
<RandL:Service serviceNr="67" description="" pointsEarned="47" condition="true" pointsBurned="10" partner="/0" level="/7"/>
<RandL:Container_RandL>
<ref_RandL_Customer gender="female" isMale="false" name="YiMK" title="m" age="11" programs="/4" memberships="/1">
<dateOfBirth year="9" month="63" day="16"/>
</ref_RandL_Customer>
<ref_RandL_Customer gender="female" isMale="true" name="VAB2" title="FjO" age="25" programs="/4" memberships="/1"/>
<ref_RandL_Customer gender="female" isMale="true" name="H" title="dGh" age="83" programs="/4" memberships="/1"/>
<ref_RandL_Customer isMale="false" name="E1k" title="S" age="55" programs="/4" memberships="/1"/>
<ref_RandL_Customer isMale="false" name="Y" title="iojK" age="24" programs="/4" cards="/8" memberships="/1"/>
</RandL:Container_RandL>
<RandL:ServiceLevel name="hz" program="/4" availableServices="/5 /2" Membership="/1"/>
<RandL:CustomerCard valid="true" color="gold" owner="/6/@ref_RandL_Customer.4" Membership="/1" transactions="/3"/>
<RandL:LoyaltyAccount points="13" number="41" Membership="/1" transactions="/3"/>
</xmi:XMI>
Sirius (the Eclipse run of RoyalAndLoyal Ecore modelling) generates (.randl) files in the form :
<RandL:Container_RandL xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:RandL="http://de.tuhh.sts.octopus/octopus2emfatic/2006/RandL">
<ref_RandL_Customer/>
<ref_RandL_CustomerCard/>
<ref_RandL_LoyaltyProgram/>
<ref_RandL_TransactionReport/>
<ref_RandL_Burning/>
There is a small difference. ANd Sirius does not like it.
I'll ask the same question again, with some emphasis:
I would like to edit that XMI instance (to make it conforms with OCL constraints) with a graphical tool AND save it in the same XMI style. I have many files in the same format I have to edit.
Note that I open the instance programmatically afterward, via EMF jars (org.eclipse.emf.ecore and org.eclipse.emf.common - both v2.11) and they don't mind the xmi:XMI style.
[edit: I found that this is related : https://www.eclipse.org/forums/index.php/t/1077730/ ]
[Updated on: Wed, 16 August 2017 20:50] Report message to a moderator
FUDForum. Page generated in 0.03771 seconds
