Infer local variable inside a method [message #1770669] |
Wed, 16 August 2017 05:42 |
Amit Yadav Messages: 28 Registered: June 2017 |
I ma using Xbase and JvmModelInferrer to infer and generate code based on my model. I need to define a method within a generated class. The body of this method contains some logic (which is not coming from the DSL). This logic requires declaring a local variable within the class.
I am wondering what is the best way to achieve this?
Say for example I need to create a map
Map<String, SomeClass> blah;
I tried doing the following in the setBody function for the JvmOperation I am creating.
JvmTypeReference ref = typeReferenceBuilder.typeRef(Map.class,
typeReferenceBuilder.typeRef(String.class),
typeReferenceBuilder.typeRef(SomeClass.class));
jvmTypesBuilder.setBody(op, tree -> {
tree.append(ref.getSimpleName()).append(" ref blah;");
But this shows up as
Map blah;
in the generated code.
Then I tried
tree.append(ref.getIdentifier()).append(" ref blah;");
but that shows up as
java.util.Map<java.lang.String, com.example.SomeClass> blah;
is there a way to get this to generate
in the generated code ?
Re: Infer local variable inside a method [message #1770679 is a reply to message #1770672] |
Wed, 16 August 2017 08:16 |
well, should have been easy to try it in xtend and have a look at the generated java code
public class MyDslJvmModelInferrer extends AbstractModelInferrer {
@Inject
@Extension
private JvmTypesBuilder _jvmTypesBuilder;
protected void _infer(final Model element, final IJvmDeclaredTypeAcceptor acceptor, final boolean isPreIndexingPhase) {
EList<Greeting> _greetings = element.getGreetings();
for (final Greeting greeting : _greetings) {
String _name = greeting.getName();
String _plus = ("test." + _name);
final Procedure1<JvmGenericType> _function = (JvmGenericType it) -> {
EList<JvmMember> _members = it.getMembers();
final Procedure1<JvmOperation> _function_1 = (JvmOperation it_1) -> {
StringConcatenationClient _client = new StringConcatenationClient() {
protected void appendTo(StringConcatenationClient.TargetStringConcatenation _builder) {
_builder.append(Map.class);
_builder.append("<");
_builder.append(String.class);
_builder.append(",");
_builder.append(Integer.class);
_builder.append("> map;");
this._jvmTypesBuilder.setBody(it_1, _client);
JvmOperation _method = this._jvmTypesBuilder.toMethod(greeting, "demo", this._typeReferenceBuilder.typeRef(Void.TYPE), _function_1);
this._jvmTypesBuilder.<JvmOperation>operator_add(_members, _method);
acceptor.<JvmGenericType>accept(this._jvmTypesBuilder.toClass(greeting, _plus), _function);
public void infer(final EObject element, final IJvmDeclaredTypeAcceptor acceptor, final boolean isPreIndexingPhase) {
if (element instanceof Model) {
_infer((Model)element, acceptor, isPreIndexingPhase);
return;
} else if (element != null) {
_infer(element, acceptor, isPreIndexingPhase);
return;
} else {
throw new IllegalArgumentException("Unhandled parameter types: " +
Arrays.<Object>asList(element, acceptor, isPreIndexingPhase).toString());
Twitter : @chrdietrich
FUDForum. Page generated in 0.02148 seconds
