Home » Modeling » TMF (Xtext) » <MyDSL>TerminalsValidator class not being generated(Houston, we have a problem with the generated code.)
<MyDSL>TerminalsValidator class not being generated [message #1770569] Mon, 14 August 2017 15:01 Go to next message
David BlackFriend
Member
as in the subject: some types are missing in the generated code.
For example, my MyDSLValidator generated class is supposed to extend MyDSLTerminalsValidator, but the latter is missing. I don't think it's been generated, because it's not only missing as a type, but also as an Eclipse resource.
Any clues what to tweak to generate the artifacts properly?
Thanks in advance.
David
Re: <MyDSL>TerminalsValidator class not being generated [message #1770571 is a reply to message #1770569] Mon, 14 August 2017 15:11 Go to previous messageGo to next message
Christian Dietrich is currently online Christian DietrichFriend
Can you give any steps to reproduce? How does the header of the grammar look like, how the workflow
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: <MyDSL>TerminalsValidator class not being generated [message #1770572 is a reply to message #1770571] Mon, 14 August 2017 15:23 Go to previous messageGo to next message
David BlackFriend
Member
Sure.
As for the head of the grammar, it's this:
grammar org.instrumenteddreams.lang.Sable with org.instrumenteddreams.lang.SableTerminals
generate sable "http://www.instrumenteddreams.org/lang/Sable"
Sable:
	source+=Statement*;
The workflow (which I am running as an almost-default run config, just with two parameters for tweaking VM's memory) is this:
module org.instrumenteddreams.lang.GenerateSable
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "org.instrumenteddreams.sable.context"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				eclipsePlugin = {
					enabled = true
				eclipsePluginTest = {
					enabled = true
				createEclipseMetaData = true
			code = {
				encoding = "UTF-8"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
		language = StandardLanguage {
			parserGenerator = {
				options = {
					backtrack = false
			name = "org.instrumenteddreams.lang.Sable"
			fileExtensions = "Sable,sable"
			serializer = {
				generateStub = false
			validator = {
				// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
Re: <MyDSL>TerminalsValidator class not being generated [message #1770577 is a reply to message #1770572] Mon, 14 August 2017 15:47 Go to previous messageGo to next message
can you please share a complete reproducible sample projects i can simply import/clone and run
Re: <MyDSL>TerminalsValidator class not being generated [message #1770579 is a reply to message #1770577] Mon, 14 August 2017 15:48 Go to previous messageGo to next message
for me it looks line you use a supergrammar without any language section in the workflow.
this makes no sense to me.
the code in the fragments does not expect that
Re: <MyDSL>TerminalsValidator class not being generated [message #1770587 is a reply to message #1770579] Mon, 14 August 2017 16:38 Go to previous messageGo to next message
David BlackFriend
Member
I've just used the wizard to generate the workflow from a sample DSL project, and then I developed the example language day by day until got a working grammar.
Should I have added manual chunks into the workflow? What sections are missing?
Re: <MyDSL>TerminalsValidator class not being generated [message #1770589 is a reply to message #1770587] Mon, 14 August 2017 16:42 Go to previous messageGo to next message
First why do you have a own Terminals grammar at all
Re: <MyDSL>TerminalsValidator class not being generated [message #1770600 is a reply to message #1770589] Mon, 14 August 2017 20:00 Go to previous messageGo to next message
David BlackFriend
Member
Christian Dietrich wrote on Mon, 14 August 2017 16:42
To make things modular and have lesser files.
Re: <MyDSL>TerminalsValidator class not being generated [message #1770601 is a reply to message #1770600] Mon, 14 August 2017 20:08 Go to previous messageGo to next message
Just inline everything into your grammar
(No super grammar)
That's the easiest way
[Updated on: Mon, 14 August 2017 20:09]
Report message to a moderator
Re: <MyDSL>TerminalsValidator class not being generated [message #1770647 is a reply to message #1770601] Tue, 15 August 2017 14:32 Go to previous messageGo to next message
David BlackFriend
Member
Christian Dietrich wrote on Mon, 14 August 2017 20:08
(No super grammar)
Thanks for your hint. It seems to help. Now I have only one missing class, SableTerminalsQuickfixProvider. I assume the easiest way to fix this is just implementing it manually.
[Updated on: Tue, 15 August 2017 14:37]
Re: <MyDSL>TerminalsValidator class not being generated [message #1770656 is a reply to message #1770647] Tue, 15 August 2017 18:00 Go to previous messageGo to next message
simply delete the existing provider and let it generate again.
then this problem should be gone
Re: <MyDSL>TerminalsValidator class not being generated [message #1770764 is a reply to message #1770656] Wed, 16 August 2017 22:17 Go to previous message
David BlackFriend
Member
It has indeed helped! Thanks again.
Previous Topic:How to use EOL to grammar
Next Topic:Infer local variable inside a method
Current Time: Thu Oct 28 09:24:30 GMT 2021
Powered by FUDForum. Page generated in 0.01467 seconds
