Home » Modeling » TMF (Xtext) » Text in Xtext
Text in Xtext [message #1770510] Sun, 13 August 2017 14:49 Go to next message
Ruchika Kumar is currently offline Ruchika KumarFriend
Member
Is there a data type of Text in Xtext? i.e. a string that is without inverted commas and could contain spaces in between words.
Re: Text in Xtext [message #1770513 is a reply to message #1770510] Sun, 13 August 2017 16:46 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
short answer: no.
what do you exactly want to achieve
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Text in Xtext [message #1770515 is a reply to message #1770513] Sun, 13 August 2017 18:07 Go to previous messageGo to next message
Member
So could we define a terminal rule which acts as a Text and we can specify it for text fields?
I just need to define an attribute of type Text and not String.
i.e. inside the model, I can simply write the value without using " " and also use spaces.
[Updated on: Sun, 13 August 2017 18:10]
Report message to a moderator
Re: Text in Xtext [message #1770518 is a reply to message #1770515] Sun, 13 August 2017 18:54 Go to previous messageGo to next message
It would be more like a datatype rule
E.g.
Stuff: ID+;
But it depends on what you ant to allow inside the string
Where it sorts and where it ends etc
Re: Text in Xtext [message #1770519 is a reply to message #1770518] Sun, 13 August 2017 19:29 Go to previous messageGo to next message
I suspect that you will find that a grammar with non-spacing spaces and without enclosing quotes for spaces is very hard to develop and probably also really painful to use. I strongly suggest a rethink. If it is useable, then perhaps it is so simple that you can handcraft a lexer/parser.
Ed Willink
Re: Text in Xtext [message #1770979 is a reply to message #1770519] Sun, 20 August 2017 12:12 Go to previous messageGo to next message
Member
Thank you both for your replies.
But ID+ would not allow me to add numbers and special characters in the feature's value. I want simple text which could include anything ranging from numbers, special chars, chars to spaces.
Re: Text in Xtext [message #1770984 is a reply to message #1770979] Sun, 20 August 2017 16:02 Go to previous message
You have to list them all
Previous Topic:IDEA Plugin Error: ClasscastException
Next Topic:DerivedState filter events
Current Time: Sun Oct 02 16:29:17 GMT 2022
Powered by FUDForum. Page generated in 0.02418 seconds
