Re: Member end name given _1 [message #1771055 is a reply to message #1771028] |
Mon, 21 August 2017 14:06 |
James Co Messages: 8 Registered: August 2017 |
I create a directed composition between two blocks in a papyrus block diagram. In the picture, I have renamed all the ends except the new one which I call test. I also find that the datatypes that I put in a separate block diagram are copied across to the first block diagram, for some reason.
The Eclipse Modeling Tool is Version: Oxygen Release (4.7.0)
Build id: 20170620-1800
The Papyrus modeling tool is associated with feature plug-ins that are installed. The feature name is Papyrus UML Modeller 3.0.0.201706140736 and the plug in details are as follows:
Provider; Plug-in Name; version; Plug-in id
Eclipse Modeling Project; Editors for the Eclipse Project; 2.0.0.201706140736; org.eclipse.papyrus.eclipse.project.editors
Eclipse Orbit; Guava: Google Core Libraries for Java; 21.0.0.v20170206-1425; com.google.guava.
Eclipse Modeling Project; Papyrus UML Modeller; 2.0.0.201706140736; org.eclipse.papyrus.sdk
I attache the configuration and error log dumps as text files. I installed too many different extensions and don't need most of them but I like the layout with all the sysml palettes being available which I have not been able to reproduce on different builds of eclipse.
thanks!
[Updated on: Mon, 21 August 2017 14:11] Report message to a moderator
FUDForum. Page generated in 0.03494 seconds
