Home » Modeling » TMF (Xtext) » Setting up Xtext dev. environment (Help needed)(GitClone task fails with Connection timed out)
Setting up Xtext dev. environment (Help needed) [message #1769746] Thu, 03 August 2017 07:05 Go to next message
Neeraj Bhusare is currently offline Neeraj BhusareFriend
Hi All,
While setting up the dev. env., I am seeing the following error. I have tried provisioning multiple times with no luck.
Caused by: org.eclipse.jgit.errors.TransportException: git@github.com:eclipse/xtext-umbrella.git: Connection timed out: connect
  at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:159)
  at org.eclipse.jgit.transport.SshTransport.getSession(SshTransport.java:137)
  at org.eclipse.jgit.transport.TransportGitSsh$SshFetchConnection.<init>(TransportGitSsh.java:274)
  at org.eclipse.jgit.transport.TransportGitSsh.openFetch(TransportGitSsh.java:169)
  at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:136)
  at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:122)
  at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1236)
  at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:234)
  at org.eclipse.jgit.api.CloneCommand.fetch(CloneCommand.java:293)
  at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:190)
  at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.cloneRepository(GitCloneTaskImpl.java:942)
PS attached file for detailed error report.
Are these issues related 515596, 519877 ?
Can someone else please give it a try.
Tx in advance.
  • Attachment: err-src.txt
    (Size: 80.98KB, Downloaded 127 times)
Twitter : @NeerajBhusare
Blog : https://nbhusare.github.io/
Best regards, Neeraj
Re: Setting up Xtext dev. environment (Help needed) [message #1769747 is a reply to message #1769746] Thu, 03 August 2017 07:06 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
is this? : https://github.com/eclipse/xtext/issues/1092
do you sit behind a proxy?
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
[Updated on: Thu, 03 August 2017 07:07]
Report message to a moderator
Re: Setting up Xtext dev. environment (Help needed) [message #1769748 is a reply to message #1769747] Thu, 03 August 2017 07:08 Go to previous messageGo to next message
can you clone the repo on command line?
Re: Setting up Xtext dev. environment (Help needed) [message #1769749 is a reply to message #1769747] Thu, 03 August 2017 07:20 Go to previous messageGo to next message
My bad. Tx for the link.
nope.
Re: Setting up Xtext dev. environment (Help needed) [message #1769751 is a reply to message #1769749] Thu, 03 August 2017 07:27 Go to previous message
another thing you could try is to have a look at
the ssh2 settings dialog in the oomph installer (key symbol)
and have a look at the data there
(dont know if you have a github ssh key and where it is stored etc)
Previous Topic:Maven Tycho Build - Plugin Removes and Doesn't Regenerate its xtend-gen
Next Topic:Bi-direction (EOpposite) in Xtext
Current Time: Tue Oct 19 23:59:57 GMT 2021
Powered by FUDForum. Page generated in 0.02065 seconds
