Home » Language IDEs » C / C++ IDE (CDT) » Programatically read and update macros in a header file(Programatically read and update macros in a header file)
Programatically read and update macros in a header file [message #1769742] Thu, 03 August 2017 02:27 Go to next message
I need to create a view where user can READ and UPDATE the macro values in a header file of a C application.
Is there an efficient way for Eclipse CDT to programmatically READ and MODIFY the macro definitions in a header file of a C application? How? Or do I have to manually read, parse and update the file?
Re: Programatically read and update macros in a header file [message #1769790 is a reply to message #1769742] Thu, 03 August 2017 08:11 Go to previous messageGo to next message
:-) Actually I have a better place to ask questions like this, the cdt-dev mailing list:
questions regarding CDT guts and extending CDT should be asked on
cdt-dev mailing list, it is intention on this list
https://dev.eclipse.org/mhonarc/lists/cdt-dev/msg32224.html
Sign-up here https://dev.eclipse.org/mailman/listinfo/cdt-dev
Re: Programatically read and update macros in a header file [message #1769854 is a reply to message #1769790] Fri, 04 August 2017 04:44 Go to previous messageGo to next message
Thanks, found out its possible to read the macros in a file via IIndexManager or via ITranslationUnit. However, both classes do not seem to provide a way to update the macro values to a file.
Re: Programatically read and update macros in a header file [message #1769856 is a reply to message #1769854] Fri, 04 August 2017 04:53 Go to previous messageGo to next message
Working in the same way as refactoring does you can edit the file. Its not my area (so I don't know limitations). I see you have posted to cdt-dev, hopefully you can get a better quality answer there.
Re: Programatically read and update macros in a header file [message #1769976 is a reply to message #1769856] Mon, 07 August 2017 05:00 Go to previous messageGo to next message
Using the CRefactoring class is not appropriate for my case because I will be providing my own view. (I think it was you who mentioned that in some thread long ago). Anyway, I tried using ASTRewrite instead but ASTRewrite does not support rewriting preprocessor statements yet. Can you confirm this? Thanks.
Re: Programatically read and update macros in a header file [message #1770014 is a reply to message #1769976] Mon, 07 August 2017 10:02 Go to previous message
Hi, I can't confirm because I don't know. Nate or Doug on the cdt-dev list should hopefully know.
Previous Topic:Secure storage - need some clarification
Next Topic:error compiling project in eclipse C++ for intel galileo
Current Time: Sat Nov 08 02:14:06 EST 2025
Powered by FUDForum. Page generated in 0.05196 seconds
