Home » Eclipse Projects » Sirius » Connected edges inside the node
Connected edges inside the node [message #1769599] Wed, 02 August 2017 07:06 Go to next message
Martin Jedlicka is currently offline Martin JedlickaFriend
I have a question on the edges to connect nodes.
Each edge has the setting:
  • type Manhattan
  • Ends Centering Both
Each node is type Workspace Image.
When I create an edge between two nodes, everything looks fine.
When I begin to move the nodes, the edges are suddenly changed so that they are not at the edge of the node but differently (according to the grid) within the node (see picture).
Is it a Sirius error (GMF) or error setting on my side?
Thanks.
Martin
Re: Connected edges inside the node [message #1769605 is a reply to message #1769599] Wed, 02 August 2017 07:51 Go to previous message
Laurent Redor is currently offline Laurent RedorFriend
It seems to be a Sirius bug. Can you create a Sirius bugzilla [1] with steps to reproduce (and the Sirius version used)?
Laurent
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Sirius
Laurent Redor - Obeo
Previous Topic:Open Dialog - Group from other Domain Class
Next Topic:Open Dialog vs Properties View
Current Time: Thu Feb 25 14:39:29 GMT 2021
Powered by FUDForum. Page generated in 0.02352 seconds
