Home » Eclipse Projects » Sirius » Only one label when multiple edges with same target mappings
Only one label when multiple edges with same target mappings [message #1769425] Mon, 31 July 2017 13:19 Go to next message
sonny selhorst is currently offline sonny selhorstFriend
Member
Dear,
I am sorry if this question is due to my lack of knowledge with meta-modeling and MDD in general. I am making a tool with which someone can make EER diagrams with UML notation for my master thesis. I have almost no experience with Java, so the professor that guides me decided that it would be a good idea to have me test if it is truly so that you don't need any programming experience to make use of the Sirius platform.
In my sample model, I should be able to define superclasses and subclasses and have them connected by a generalization edge. This generalization edge should then have only ONE label. This works as long as there is only one subclass.
Once there are multiple subclasses for one superclass, a label gets created for every subclass if I define the label under my edge style. This should not happen, only one label should be present that defines the generalization.
I have added an image of how it should look like, I hope that helps. I have also added all files which I created to create my diagram.
Thank you very much in advance.
Kind regards,
Sonny
Re: Only one label when multiple edges with same target mappings [message #1769434 is a reply to message #1769425] Mon, 31 July 2017 14:16 Go to previous message
Laurent Redor is currently offline Laurent RedorFriend
Unfortunately, it's not possible. In the image, there is not only one edge but several edges. For example, for Person superclass:
* One edge between Staff --> Person
* One edge between PrivateOwner --> Person
* One edge between Client --> Person
The layout, "tree layout", applied to these edge, draws a common segment to all edges but there are really 3 edges (and so 3 labels).
A solution is maybe to have a conditional style for the edges with only a label for the first sub class. I've not tested it.
Laurent Redor - Obeo
Previous Topic:Computed color expression to return R,G,B in one service call
Next Topic:NPE in EdgeLabelQuery when moving node
Current Time: Thu Mar 04 11:03:34 GMT 2021
Powered by FUDForum. Page generated in 0.01577 seconds
