Home » Eclipse Projects » NatTable » Not able to select Row Header when only one column is present
Not able to select Row Header when only one column is present [message #1769242] Fri, 28 July 2017 07:40 Go to next message
Gaurav Tripathi is currently offline Gaurav TripathiFriend
Member
There are cases when in NatTable I just have one column with many rows.
In such cases, I am not able to click/select on row header.
I don't know why NatTable is behaving like this or is this any bug.
Please let me know the solution if any.
Thanks in advance.
Re: Not able to select Row Header when only one column is present [message #1769250 is a reply to message #1769242] Fri, 28 July 2017 08:57 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
Can't tell what your issue is. Such a behavior is not known to me. Therefore it is no known bug. And if I take one of our examples and change it to only show one column everything still works as expected.
Re: Not able to select Row Header when only one column is present [message #1769276 is a reply to message #1769250] Fri, 28 July 2017 13:49 Go to previous messageGo to next message
Member
Thanks for such a quick reply.
I took your example _513_FreezeExample. In this, I freeze 1st column and remaining column I hide it and then I am not able to select row header.
In my case by default, I will freeze 1st column. So when there is no more than 1 column I am not able to select row header.
Re: Not able to select Row Header when only one column is present [message #1769283 is a reply to message #1769276] Fri, 28 July 2017 15:01 Go to previous messageGo to next message
Please provide all relevant information. You did not mention that the freeze layer is involved.
Need to check, but it is not known
Re: Not able to select Row Header when only one column is present [message #1769370 is a reply to message #1769283] Mon, 31 July 2017 06:24 Go to previous message
Member
Providing all relevant information:
IColumnPropertyAccessor<EObject> columnPropertyAccessor = new ContainerColumnPropertyAccessor(propNames,propertyToLabelMap);
		bodyDataProvider = new ListDataProvider<EObject>(eventList, columnPropertyAccessor);
		final DataLayer bodyDataLayer = new DataLayer(bodyDataProvider);
		ColumnReorderLayer columnReorderLayer = new ColumnReorderLayer(bodyDataLayer);
		ColumnHideShowLayer columnHideShowLayer = new ColumnHideShowLayer(columnReorderLayer);
		selectionLayer = new SelectionLayer(columnHideShowLayer);
		final ViewportLayer viewportLayer = new ViewportLayer(selectionLayer);
		final FreezeLayer freezeLayer = new FreezeLayer(selectionLayer);
		final CompositeFreezeLayer compositeFreezeLayer = new CompositeFreezeLayer(freezeLayer, viewportLayer,
				selectionLayer);
		// build the column header layer
		IDataProvider columnHeaderDataProvider = new CustomColumnHeaderDataProvider(propNames, propertyToLabelMap);
		DataLayer columnHeaderDataLayer = new DefaultColumnHeaderDataLayer(columnHeaderDataProvider);
		ColumnHeaderLayer columnHeaderLayer = new ColumnHeaderLayer(columnHeaderDataLayer, compositeFreezeLayer,
				selectionLayer);
		// build the row header layer
		IDataProvider rowHeaderDataProvider = new CustomRowHeaderDataProvider(bodyDataProvider);
		DataLayer rowHeaderDataLayer = new DefaultRowHeaderDataLayer(rowHeaderDataProvider);
		ILayer rowHeaderLayer = new RowHeaderLayer(rowHeaderDataLayer, compositeFreezeLayer, selectionLayer);
		// build the corner layer
		IDataProvider cornerDataProvider = new DefaultCornerDataProvider(columnHeaderDataProvider,
		DataLayer cornerDataLayer = new DataLayer(cornerDataProvider);
		ILayer cornerLayer = new CornerLayer(cornerDataLayer, rowHeaderLayer, columnHeaderLayer);
		// build the grid layer
		GridLayer gridLayer = new GridLayer(compositeFreezeLayer, columnHeaderLayer, rowHeaderLayer, cornerLayer);
		final ColumnOverrideLabelAccumulator columnLabelAccumulator = new ColumnOverrideLabelAccumulator(bodyDataLayer);
		bodyDataLayer.registerCommandHandler(new DeleteRowCommandHandler<EObject>(((ListDataProvider<EObject>)bodyDataProvider).getList(), getSelectionLayer()));
			private NatTable generateNatTable(Composite parent, ScrolledForm body, Set<EObject> propertyNamesObject,
			final SelectionLayer selectionLayer, final ViewportLayer viewportLayer, final FreezeLayer freezeLayer,
			final CompositeFreezeLayer compositeFreezeLayer, GridLayer gridLayer,
			DefaultRowStyleConfiguration rowStyleConfiguration, LinkedHashMap<String, EObject> propertyToLabelMap) {
		final NatTable natTable = new NatTable(parent, gridLayer, false);
		TableWrapData td = new TableWrapData(TableWrapData.FILL_GRAB, TableWrapData.FILL_GRAB,
				(body.getBounds().height / 11)-3, 1);
		natTable.setLayoutData(td);
		natTable.addConfiguration(new DefaultNatTableStyleConfiguration() {
				cellPainter = new LineBorderDecorator(new TextPainter(false, true, 3, true));
		natTable.addConfiguration(new DefaultFreezeGridBindings());
		natTable.addConfiguration(rowStyleConfiguration);
		natTable.addConfiguration(new ColumnHeaderRightClickConfig(natTable, compositeFreezeLayer, freezeLayer,
				viewportLayer, selectionLayer));
		natTable.addConfiguration(new EditorConfiguration(propertyNamesObject));
		natTable.addConfiguration(new DefaultColumnHeaderStyleConfiguration(){
				font = GUIHelper.getFont(new FontData[] { new FontData("Calibri", 10, SWT.BOLD) });
				cellPainter = new BeveledBorderDecorator(new TextPainter(false, true, true , true));
		Menu menu = createRightClickMenu(natTable, selectionLayer);
		natTable.addConfiguration(new AbstractUiBindingConfiguration() {
			public void configureUiBindings(UiBindingRegistry uiBindingRegistry) {
				uiBindingRegistry.registerMouseDownBinding(
						new MouseEventMatcher(SWT.NONE, GridRegion.BODY, MouseEventMatcher.RIGHT_BUTTON),
						new CellPopupMenuAction(menu, selectionLayer, propertyToLabelMap));
		natTable.configure();
		natTable.doCommand(new FreezeColumnCommand(compositeFreezeLayer, 0, false, false));
		natTableBodyChangeListener(body, natTable);
		new NatTableContentTooltip(natTable, GridRegion.BODY,GridRegion.COLUMN_HEADER);
		return natTable;
Previous Topic:How to set native SWT images in CheckBoxPainter?
Next Topic:Dynamically create new row on commit last row's last cell's CellEditor
Current Time: Sat Dec 07 02:05:43 GMT 2019
Powered by FUDForum. Page generated in 0.02246 seconds
