Home » Eclipse Projects » NatTable » How to set native SWT images in CheckBoxPainter?
How to set native SWT images in CheckBoxPainter? [message #1768971] Tue, 25 July 2017 09:49 Go to next message
Bel Razom is currently offline Bel RazomFriend
does anybody know, where to find native SWT images to set them in CheckBoxPainter and DisabledCheckboxPainter?
index.php/fa/30115/0/
Is there any plugin, that can be refered in a way like this:
checkedImg = AbstractUIPlugin.imageDescriptorFromPlugin(PLUGIN_ID, imagePath).getImage();
CheckBoxPainter(checkedImage, uncheckedImage);
DisabledCheckboxPainter(checkedImage, uncheckedImage);
Can you share your experience of setting SWT style?
Re: How to set native SWT images in CheckBoxPainter? [message #1768977 is a reply to message #1768971] Tue, 25 July 2017 10:48 Go to previous message
Dirk Fauth is currently offline Dirk FauthFriend
The checkboxes displayed by SWT are rendered by the OS. IIRC there are no images for them available anywhere. A quite old post suggests to make a screenshot from the widget in different states and keep the images in RAM to use them in the table. This would be the only way to be OS independent.
Previous Topic:Simple filter without row
Next Topic:Not able to select Row Header when only one column is present
Current Time: Mon Jan 20 04:00:58 GMT 2020
Powered by FUDForum. Page generated in 0.02051 seconds
