Home » Newcomers » Newcomers » Creating Workspace(How to "bypass" / set proper Linux security in assigning Workspace )
Creating Workspace [message #1768920] Mon, 24 July 2017 22:58 Go to next message
Very basis issue
Using Eclipse 3..8 on Raspbian OS (Raspberry Pi)
Cannot finish compiling because not having "permissions " to write to workspace.
Ideally I like to use external flash drive as Eclipse workplace.
Since Eclipse is GUI app, is there a way I can select the desired workspace and set the correct permissions from within Eclipse IDE ?
I got lost trying to use commands , sorry.
Re: Creating Workspace [message #1768930 is a reply to message #1768920] Tue, 25 July 2017 01:12 Go to previous messageGo to next message
You can use File -> Switch Workspace to select a new workspace location, but file permissions you'll have to set using the OS to make the folder writable.
Re: Creating Workspace [message #1768995 is a reply to message #1768920] Tue, 25 July 2017 09:58 Go to previous messageGo to next message
Does this apply to Eclipse 3.8 only?
Just downloaded and installed latest Oxygen and hand no problem using default Workspace.
Also when I change Workspace in 3.8 the whole app will reload.
Re: Creating Workspace [message #1769050 is a reply to message #1768995] Wed, 26 July 2017 01:49 Go to previous messageGo to next message
I don't believe anything has changed in this regard. When you installed Oxygen, I assume the default Workspace wasn't on your flash drive, but rather in your home folder, which no doubt is writable by you. And yes, switching Workspaces will restart the application. The Workspace location (and particular the .metadata it contains), is needed by many bundles as they initialized, so is baked in early...
Re: Creating Workspace [message #1769101 is a reply to message #1769050] Wed, 26 July 2017 10:26 Go to previous message
Thanks, I need to pay attention where the default Workspace resides.
Can I ask another question about eclipse or should I make new post?
Previous Topic:Eclipse naming /versioning conventions ?
Next Topic:install qusetion on linux
Current Time: Tue Apr 29 18:23:06 EDT 2025
Powered by FUDForum. Page generated in 0.15592 seconds
