Random Exit code 13 while running maven suite [message #1768899] |
Mon, 24 July 2017 17:58 |
Guillermo Reobasco Messages: 2 Registered: July 2017 |
When trying to run test suite via maven runner, sometimes it will fail with Exit code 13.
The issue is totally random, but frequent enough to be a problem.
Any thoughts are welcome!
Eclipse version: 4.6.2
Rcptt Runner: 2.1.0
OS: Windows 7
Here is the Runner log:
build 24-Jul-2017 17:01:52 [INFO] Runner command line is cmd.exe /X /C ""C:\Program Files\Java\jdk1.8.0_73\jre\bin\java.exe" -Xmx1024m -jar D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\runner\eclipse\plugins\org.eclipse.equinox.launcher_1.3.200.v20160318-1642.jar -application org.eclipse.rcptt.runner.headless -data D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\runner-workspace -aut D:\bb\TTS-STL63-JOB1\studio-q7-sanity\..\org.mule.tooling.products\org.mule.tooling.studio.product\target\products\studio.product\win32\win32\x86_64\AnypointStudio -autWsPrefix D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\aut-ws- -autConsolePrefix D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\results\aut-console- -autVMArgs -Xmx1024m;-verbose:gc;-XX:+PrintGCDetails;-XX:+HeapDumpOnOutOfMemoryError;-XX:HeapDumpPath=D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target;-Dorg.mule.tooling.ui.widgets.disable_popups=true -memoryUsage -q7report D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\results\maven.module.sanity.report -htmlReport D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\results\maven.module.sanity.html -junitReport D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\surefire-reports\TEST-maven.module.sanity.xml -import D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\projects\maven.module.sanity -testOptions execTimeout=14400;testExecTimeout=1800 -timeout 14400 -shutdownListenerPort 9391 -suites SanityNightlySuite"
build 24-Jul-2017 17:01:52 [INFO] The execution timeout is set to 14400 seconds
build 24-Jul-2017 17:01:57 [INFO] Started at Mon Jul 24 14:01:57 ART 2017
build 24-Jul-2017 17:01:57 [INFO] RCPTT Runner version: 2.1
build 24-Jul-2017 17:01:59 [INFO] An error has occurred. See the log file
build 24-Jul-2017 17:01:59 [INFO] D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\runner-workspace\.metadata\.log.
build 24-Jul-2017 17:01:59 [INFO] Runner exit code is: 13
build 24-Jul-2017 17:01:59 [INFO] ------------------------------------------------------------------------
build 24-Jul-2017 17:01:59 [INFO] Reactor Summary:
build 24-Jul-2017 17:01:59 [INFO] studio-rcptt ....................................... SUCCESS [ 2.403 s]
build 24-Jul-2017 17:01:59 [INFO] Anypoint Studio Sanity Test ........................ FAILURE [01:16 min]
build 24-Jul-2017 17:01:59 [INFO] BUILD FAILURE
build 24-Jul-2017 17:01:59 [INFO] Total time: 01:20 min
build 24-Jul-2017 17:01:59 [INFO] Finished at: 2017-07-24T14:01:59-03:00
build 24-Jul-2017 17:01:59 [INFO] Final Memory: 12M/115M
build 24-Jul-2017 17:01:59 [ERROR] Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.1.0:execute (default-execute) on project maven.module.sanity: Failed to launch RCPTT runner. Runner exit code is: 13 -> [Help 1]
build 24-Jul-2017 17:01:59 [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
build 24-Jul-2017 17:01:59 [ERROR] Re-run Maven using the -X switch to enable full debug logging.
build 24-Jul-2017 17:01:59 [ERROR] For more information about the errors and possible solutions, please read the following articles:
build 24-Jul-2017 17:01:59 [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
build 24-Jul-2017 17:01:59 [ERROR] After correcting the problems, you can resume the build with the command
build 24-Jul-2017 17:01:59 [ERROR] mvn <goals> -rf :maven.module.sanity
build 24-Jul-2017 17:02:00 java.net.ConnectException: Connection refused: connect
build 24-Jul-2017 17:02:00 [INFO] Process terminated. Send shutdown request to RCPTT runner.
simple 24-Jul-2017 17:02:00 Failing task since return code of [D:\Users\matiaspentreath\apache-maven-3.2.3\bin\mvn.bat --batch-mode -Djava.io.tmpdir=D:\Users\MATIAS~1\AppData\Local\Temp\1\TTS-STL63-JOB1 clean install -Psanity -Dstudio.artifact=https://mule-studio.s3.amazonaws.com/6.2.5-U5/AnypointStudio-for-win-64bit-6.2.5-201705040300.zip -Dstudio.md5=3a28cd6d9a84498d06587f24e15a45ef -Dskip.AUT.download=${skip.AUT.download}] was 1 while expected 0
Here is the Workspace Log:
!SESSION 2017-07-24 14:01:52.538 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_73
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -application org.eclipse.rcptt.runner.headless -aut D:\bb\TTS-STL63-JOB1\studio-q7-sanity\..\org.mule.tooling.products\org.mule.tooling.studio.product\target\products\studio.product\win32\win32\x86_64\AnypointStudio -autWsPrefix D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\aut-ws- -autConsolePrefix D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\results\aut-console- -autVMArgs -Xmx1024m;-verbose:gc;-XX:+PrintGCDetails;-XX:+HeapDumpOnOutOfMemoryError;-XX:HeapDumpPath=D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target;-Dorg.mule.tooling.ui.widgets.disable_popups=true -memoryUsage -q7report D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\results\maven.module.sanity.report -htmlReport D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\results\maven.module.sanity.html -junitReport D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\surefire-reports\TEST-maven.module.sanity.xml -import D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\projects\maven.module.sanity -testOptions execTimeout=14400;testExecTimeout=1800 -timeout 14400 -shutdownListenerPort 9391 -suites SanityNightlySuite
Command-line arguments: -application org.eclipse.rcptt.runner.headless -data D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\runner-workspace -aut D:\bb\TTS-STL63-JOB1\studio-q7-sanity\..\org.mule.tooling.products\org.mule.tooling.studio.product\target\products\studio.product\win32\win32\x86_64\AnypointStudio -autWsPrefix D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\aut-ws- -autConsolePrefix D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\results\aut-console- -autVMArgs -Xmx1024m;-verbose:gc;-XX:+PrintGCDetails;-XX:+HeapDumpOnOutOfMemoryError;-XX:HeapDumpPath=D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target;-Dorg.mule.tooling.ui.widgets.disable_popups=true -memoryUsage -q7report D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\results\maven.module.sanity.report -htmlReport D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\results\maven.module.sanity.html -junitReport D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\surefire-reports\TEST-maven.module.sanity.xml -import D:\bb\TTS-STL63-JOB1\studio-q7-sanity\target\projects\maven.module.sanity -testOptions execTimeout=14400;testExecTimeout=1800 -timeout 14400 -shutdownListenerPort 9391 -suites SanityNightlySuite
!ENTRY org.eclipse.compare.win32 4 0 2017-07-24 14:01:55.409
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.compare.win32 [28]
Unresolved requirement: Require-Bundle: org.eclipse.ui.forms; bundle-version="[3.4.0,4.0.0)"
Unresolved requirement: Require-Bundle: org.eclipse.compare; bundle-version="[3.5.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.compare; bundle-version="3.6.0.v20160418-1534"; singleton:="true"
org.eclipse.compare [29]
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.5.0,4.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:444)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.compare 4 0 2017-07-24 14:01:55.424
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.compare [29]
!ENTRY org.eclipse.equinox.security.ui 4 0 2017-07-24 14:01:55.487
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.security.ui [120]
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.4.0,4.0.0)"
!ENTRY org.eclipse.jdt.junit 4 0 2017-07-24 14:01:55.518
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jdt.junit [138]
Unresolved requirement: Require-Bundle: org.eclipse.ui.ide; bundle-version="[3.5.0,4.0.0)"
!ENTRY org.eclipse.jdt.launching.macosx 4 0 2017-07-24 14:01:55.518
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jdt.launching.macosx [139]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(osgi.os=macosx)"
!ENTRY org.eclipse.jdt.launching.ui.macosx 4 0 2017-07-24 14:01:55.518
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jdt.launching.ui.macosx [140]
!ENTRY org.eclipse.ltk.ui.refactoring 4 0 2017-07-24 14:01:55.518
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ltk.ui.refactoring [155]
!ENTRY org.eclipse.pde.ds.annotations 4 0 2017-07-24 14:01:55.518
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.pde.ds.annotations [164]
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.105.0,4.0.0)"
!ENTRY org.eclipse.pde.runtime 4 0 2017-07-24 14:01:55.549
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.pde.runtime [168]
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.3.0,4.0.0)"
!ENTRY org.eclipse.search 4 0 2017-07-24 14:01:55.580
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.search [251]
!ENTRY org.eclipse.osgi 4 0 2017-07-24 14:01:57.842
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (48).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:795)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:724)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:470)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:325)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:334)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:407)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:361)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:353)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.rcptt.internal.core.RcpttPlugin.start(RcpttPlugin.java:59)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:774)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:767)
at org.eclipse.rcptt.runner.HeadlessRunnerApp.start(HeadlessRunnerApp.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: java.lang.IllegalStateException: No instance data can be specified.
at org.eclipse.core.internal.runtime.DataArea.assertLocationInitialized(DataArea.java:50)
at org.eclipse.core.internal.runtime.DataArea.getStateLocation(DataArea.java:124)
at org.eclipse.core.internal.runtime.InternalPlatform.getStateLocation(InternalPlatform.java:539)
at org.eclipse.core.runtime.Plugin.getStateLocation(Plugin.java:289)
at org.eclipse.core.internal.resources.LocalMetaArea.<init>(LocalMetaArea.java:59)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:456)
... 51 more
Root exception:
!ENTRY org.eclipse.rcptt.core 4 0 2017-07-24 14:01:59.137
!MESSAGE Couldn't start model manager
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IResourceChangeListener
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (48).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
... 35 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
... 44 more
... 51 more
!ENTRY org.eclipse.osgi 4 0 2017-07-24 14:01:59.137
!MESSAGE An error occurred while automatically activating bundle org.eclipse.debug.core (51).
!STACK 0
org.osgi.framework.BundleException: Error starting module.
at org.eclipse.osgi.container.Module.doStart(Module.java:590)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/core/resources/ISaveParticipant
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671)
at java.lang.Class.getConstructor0(Class.java:3075)
at java.lang.Class.newInstance(Class.java:412)
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:758)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:711)
... 26 more
... 29 more
... 44 more
... 51 more
Root exception:
... 29 more
... 44 more
... 51 more
!ENTRY org.eclipse.osgi 4 0 2017-07-24 14:01:59.184
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/debug/core/ILaunch
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.debug.core (51).
... 14 more
Caused by: org.osgi.framework.BundleException: Error starting module.
... 23 more
... 26 more
... 29 more
... 44 more
... 51 more
!ENTRY org.eclipse.rcptt.launching 4 0 2017-07-24 14:01:59.215
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.rcptt.internal.launching.Q7LaunchingPlugin.stop() of bundle org.eclipse.rcptt.launching.
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:850)
at org.eclipse.osgi.internal.framework.EquinoxBundle.stopWorker0(EquinoxBundle.java:946)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.stopWorker(EquinoxBundle.java:314)
at org.eclipse.osgi.container.Module.doStop(Module.java:636)
at org.eclipse.osgi.container.Module.stop(Module.java:498)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1661)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1580)
at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:253)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:147)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:191)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/debug/core/ILaunch
at org.eclipse.rcptt.internal.launching.Q7LaunchingPlugin.stop(Q7LaunchingPlugin.java:80)
at org.eclipse.osgi.internal.framework.BundleContextImpl$4.run(BundleContextImpl.java:830)
at org.eclipse.osgi.internal.framework.BundleContextImpl$4.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:823)
... 13 more
... 23 more
... 26 more
... 29 more
... 44 more
... 51 more
Root exception:
[Updated on: Tue, 25 July 2017 13:37] Report message to a moderator
FUDForum. Page generated in 0.03029 seconds
