Home » Modeling » TMF (Xtext) » Using a customized XbaseValidator
Using a customized XbaseValidator [message #1768739] Sun, 23 July 2017 08:55 Go to next message
Marco Ullrich is currently offline Marco UllrichFriend
Hello everyone,
I want to customize Xbase, so that assignments to parameters are possible.
I already customized the JvmModelGenerator to generate the appropriate code and it works.
But I also need to customize the validation of Xbase.
I did subclass the XbaseValidator and customized the checkAssignment method.
My problem is: How do i inject my customized XbaseValidator instead of the original one?
I already subclassed and customized th XbaseRuntimeModule:
class BpoXbaseRuntimeModule extends XbaseRuntimeModule {
	@SingletonBinding(eager=true)
	override Class<? extends XbaseValidator> bindXbaseValidator() {
		return BpoXbaseValidator;
and the XbaseStandaloneSetup:
class BpoXbaseStandaloneSetup extends XbaseStandaloneSetup{
	override Injector createInjector() {
		return Guice.createInjector(new BpoXbaseRuntimeModule());
	def static void doSetup() {
		new BpoXbaseStandaloneSetup().createInjectorAndDoEMFRegistration()
But my validator is not injected during runtime.
Do I have to customize another part?
How does the runtime know wich StandaloneSetup to use?
Thanks in advance and best regards,
Marco
[Updated on: Sun, 23 July 2017 08:56]
Report message to a moderator
Re: Customizing assignement to parameters in Xbase [message #1768740 is a reply to message #1768739] Sun, 23 July 2017 08:59 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
You should add the bindings to the pregenerated runtimemodule.
You should override the bindYourdslValidator method
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Customizing assignement to parameters in Xbase [message #1768742 is a reply to message #1768740] Sun, 23 July 2017 09:48 Go to previous message
Oh, it seems i over complicated things...
Overriding the checkAssignment-Method in the default- Validator did the trick, hence it inherits from XbaseValidator.
Thank you for setting me back on track Christian!
Have a nice day! :)
Previous Topic:Github Pull Requests
Next Topic:Unable to resolve some references in .mwe2 file
Current Time: Sat Oct 16 10:22:05 GMT 2021
Powered by FUDForum. Page generated in 0.02598 seconds
