Re: Jubula not working with Jenkins [message #1770053 is a reply to message #1769950] |
Mon, 07 August 2017 18:45   |
Jubula needs a display, keyboard and mouse during test execution.
If you use a standard Jenkins installation the jobs will run without a display connection. You have to either start Jenkins as a normal program, i.e. not as a service, or you need to allow the Jenkins service to interact with the desktop which might or might not work as expected depending on your windows version, some graphics settings and the phase of the moon ;-)
Easiest way is to have a dedicated Jenkins slave, preferably on a virtual machine, which is started as a program and used exclusively to run tests.
I am not sure if there is a tutorial on how to do this. Alex, Marvin, any hints?
Re: Jubula not working with Jenkins [message #1771007 is a reply to message #1771005] |
Mon, 21 August 2017 07:11   |
Again, have you checked that the Jenkins server is running with access to the display, keyboard and mouse? If you use a standard Jenkins setup the service and all its jobs will run without a display connection which will make Jubula test execution fail.
FUDForum. Page generated in 0.02666 seconds
