Home » Modeling » TMF (Xtext) » Qualify EReference before switching from Local to Global Scope
Qualify EReference before switching from Local to Global Scope [message #1768551] Wed, 19 July 2017 22:29 Go to next message
Christian Schulze is currently offline Christian SchulzeFriend
I'm currently working on a language that does namespace-based imports like in Java (incl. a package declaration at the beginning of the file).
Example Grammar:
File:
  'package' name=QualifiedName ';'
  (types += Type)*
Import:
  'import' importedNamespace=QualifiedNameWithWildcard ';'
Type:
  'type' name=ID (':' baseTypes += [Type|QualifiedName] (',' baseTypes += [Type|QualifiedName])*)? ';'
Let's consider the following files.
File1.mydsl
package a.b.c;
type FirstType;
File2.mydsl
package d.e.f;
type SecondType : a.b.c.FirstType;
File3.mydsl
package g.h.i;
import a.b.c.*;
type ThirdType : FirstType;
File4.mydsl
package a.b.c;
type FourthType : FirstType; // Couldn't resolve reference to Type 'FirstType'
Files 1-3 resolve fine as all EReferences are fully qualified when the resolution is attempted but File 4 fails. I guess it's because it uses the simple name to scan the index in the Global Scope. If so - how can I override the EReference's qualified name if it's not qualified?
If that's not the reason - what am I doing wrong?
Best regards and many thanks in advance for your help
[Updated on: Wed, 19 July 2017 22:34]
Report message to a moderator
Re: Qualify EReference before switching from Local to Global Scope [message #1768559 is a reply to message #1768551] Thu, 20 July 2017 03:53 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
looks like you missed the implicit import for the package
package org.xtext.example.mydsl.scoping;
import java.util.List;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.xtext.scoping.impl.ImportNormalizer;
import org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider;
import org.xtext.example.mydsl.myDsl.File;
public class MyDslImportedNamespaceAwareLocalScopeProvider extends ImportedNamespaceAwareLocalScopeProvider {
	protected List<ImportNormalizer> getImportedNamespaceResolvers(EObject context, boolean ignoreCase) {
		 List<ImportNormalizer> importedNamespaceResolvers = super.getImportedNamespaceResolvers(context, ignoreCase);
		 if (context instanceof File) {
			 importedNamespaceResolvers.add(doCreateImportNormalizer(getQualifiedNameConverter().toQualifiedName(((File) context).getName()), true, ignoreCase));
		 return importedNamespaceResolvers;
class MyDslRuntimeModule extends AbstractMyDslRuntimeModule {
	override void configureIScopeProviderDelegate(Binder binder) {
		binder.bind(IScopeProvider).annotatedWith(Names.named(AbstractDeclarativeScopeProvider.NAMED_DELEGATE)).to(
			MyDslImportedNamespaceAwareLocalScopeProvider)
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Previous Topic:reference errors
Next Topic:Derived Type in xtext for Yang
Current Time: Tue Oct 19 03:36:58 GMT 2021
Powered by FUDForum. Page generated in 0.01698 seconds
