Persist with secondaryTable from non PK field [message #1768550] |
Wed, 19 July 2017 22:25 |
Mariano Cano Messages: 3 Registered: December 2014 |
Hi! I have two tables:
area (
id int PK autoincrement
code varchar UNIQUE IDX
products (
area_id int
I have the secondary table defined in this way:
@SecondaryTable(name = "area", pkJoinColumns = @PrimaryKeyJoinColumn(name = "id", referencedColumnName = "area_id"))
class Product {
@Column(name="code", table = "area")
private String area;
This works fine for for createQuery to get the object. But when I try to persist:
Exception Description: Missing mapping for field [area.id].
Descriptor: RelationalDescriptor( xxx.Product --> [DatabaseTable(products), DatabaseTable(area)])
Basically what I want, is to set the area.id in product.area_id when I write product.setArea("XXX") using the code.
How could I do this? Is it possible?
Edit: bad copy/paste.. sorry
Thanks!
[Updated on: Wed, 19 July 2017 22:29] Report message to a moderator
Re: Persist with secondaryTable from non PK field [message #1768688 is a reply to message #1768550] |
Fri, 21 July 2017 14:42 |
I finally did it. Now if there is someone that could tell me if what I did is a good/bad practice would be nice. (At least is working now)
Using transformers. So the field area is defined like this:
@Transformation(fetch = FetchType.EAGER, optional = false)
@ReadTransformer(transformerClass = AreaAttributeTransformer.class)
@WriteTransformers({
@WriteTransformer(
transformerClass = AreaFieldTransformer.class,
column = @Column(name = "area_id", nullable = false))
@Expose
Then those clases work like this:
public class AreaAttributeTransformer implements AttributeTransformer {
private AbstractTransformationMapping mapping;
public void initialize(AbstractTransformationMapping abstractTransformationMapping) {
this.mapping = abstractTransformationMapping;
public Object buildAttributeValue(Record record, Object o, Session session) {
for (DatabaseField field : mapping.getFields()) {
if (field.getName().contains("area_id")) {
EntityManager em = MyEntityManagerFactory.getENTITY_MANAGER_FACTORY().createEntityManager();
List results = em.createNamedQuery("Areas.findById")
.setParameter("id", record.get(field))
.getResultList();
if (results.size() > 0)
return ((Area) results.get(0)).getCode();
return null;
public class AreaFieldTransformer implements FieldTransformer {
public Object buildFieldValue(Object o, String s, Session session) {
if (o instanceof RouSub) {
List results = em.createNamedQuery("Area.findByCode")
.setParameter("area", ((Area) o).getCode())
.getResultList();
return ((Area)results.get(0)).getId();
return null;
FUDForum. Page generated in 0.03177 seconds
