Re: get the address of input [message #1768539 is a reply to message #1768526] |
Wed, 19 July 2017 19:15 |
Banafsheh Azizi Messages: 328 Registered: July 2016 |
Thanks a lot.
Is it also possible to use Aliases for Metamodel? e.g., Is something like "IN_MM!EPackage.allInstances() -> first()" true?
As another question, I created a model in my eol program. Then I pass the URI of the model as you said to java. However, before the contents of model is completely loaded the java function runs. It causes the java function works with empty model and get error. What should I do?
and also how can I check the model is empty or not?
Member of MDSE Research Group
http://mdse.ui.ac.ir
[Updated on: Wed, 19 July 2017 19:18] Report message to a moderator
FUDForum. Page generated in 0.03398 seconds
