Re: C++ generation is missing [message #1768511 is a reply to message #1768493] |
Wed, 19 July 2017 15:18 |
I updated the wiki page, thanks for pointing this out.
If C++ is not in the list of "install Papyrus additional components", then you are likely already using the Eclipse oxygen release of Papyrus for which C++ code generation is currently not available (or a pre-neon version). An oxygen version will be available with the next release (that should come at the end of this month).
In the meantime, it is possible to install the C++ code generation for neon in an oxygen environment if you use the following update site.
http://download.eclipse.org/modeling/mdt/papyrus/components/designer/
FUDForum. Page generated in 0.02955 seconds
