Home » Newcomers » Newcomers » "The catalog could not be loaded..." when installing Eclipse
"The catalog could not be loaded..." when installing Eclipse [message #1768208] Fri, 14 July 2017 16:59 Go to next message
Missing name Mising name is currently offline Missing name Mising nameFriend
When installing the eclipse installer, it can't connect to Internet and ask me to configure network proxy. What's the problem?
I searched for this issue and it appears it occurred 1 year ago. But no solution yet.
Re: "The catalog could not be loaded..." when installing Eclipse [message #1768209 is a reply to message #1768208] Fri, 14 July 2017 17:12 Go to previous messageGo to next message
Travis NA is currently offline Travis NAFriend
I don't have a solution, just wanted to chime in that I am having the same issue. I had been using the eclipse installer 1.7.0 build 3057 (I think that was the build number) for the last two weeks or so. I installed the update earlier this morning when prompted (to build 3098) and I am now getting this error. I have tried the solutions in the threads from a year or so ago to no avail unfortunately.
Edit: It looks like its a server availability issue so we just have to wait until it gets resolved.
[Updated on: Fri, 14 July 2017 17:34]
Report message to a moderator
Re: "The catalog could not be loaded..." when installing Eclipse [message #1768210 is a reply to message #1768208] Fri, 14 July 2017 17:12 Go to previous messageGo to next message
*Deleted double post*
[Updated on: Fri, 14 July 2017 17:13]
Re: "The catalog could not be loaded..." when installing Eclipse [message #1768213 is a reply to message #1768210] Fri, 14 July 2017 17:52 Go to previous messageGo to next message
It could just be the server is having a problem. The installer is trying to access http://www.eclipse.org/setups/setups.zip so if the server is having a problem serving that (and you've never downloaded it before, in which case an older cached version would be used), you'd get a dialog about the network failure. It works for me right now...
If you're behind a proxy, you'll need to configure the proxy/network settings needed for the installer to access that URL. Note that the latest installer (for Oxygen) is version 1.8...
Ed Merks
Re: "The catalog could not be loaded..." when installing Eclipse [message #1837908 is a reply to message #1768213] Wed, 10 February 2021 09:10 Go to previous messageGo to next message
SNEHA CHELLADURAI is currently offline SNEHA CHELLADURAIFriend
any idea what needed to be changed/updated in the proxy
Re: "The catalog could not be loaded..." when installing Eclipse [message #1837953 is a reply to message #1837908] Thu, 11 February 2021 09:49 Go to previous message
No, each proxy is different so there isn't just one way to configure it. Are you actually behind a proxy? Sometimes just the system firewall can block access too. In the worst case, download a package:
Ed Merks
Previous Topic:Running Eclipse with JDK15 fails with exit code 1
Next Topic:UnsupportedConfigurationException: Project workspace location matches workspace root
Current Time: Fri Jun 25 11:32:05 GMT 2021
Powered by FUDForum. Page generated in 0.03993 seconds
