Home » Eclipse Projects » Eclipse Platform » How to know when IResource.refreshLocal has finished in Oxygen?
How to know when IResource.refreshLocal has finished in Oxygen? [message #1767952] Wed, 12 July 2017 11:12 Go to next message
Roberto A is currently offline Roberto AFriend
I'm porting my application from eclipse Mars to Oxygen.
I have my own implementation of IProgressMonitor that set a variable to true when the done() method is executed and after calling refreshLocal I'm checking if this variable is true to know when refreshLocal has finished, and it was working in previous releases to Oxygen because the refreshLocal method was calling the monitor.done() method when the refesh finish.
But in Oxygen the IResource.refreshLocal() never calls the monitor.done() method so my code is no longer working.
How can I know in Oxygen when IResource.refreshLocal() has finished?
The change in org.eclipse.core.internal.resources.Resource was done for
Bug 477409 - Replace SubProgressMonitor with SubMonitor in (https://github.com/eclipse/eclipse.platform.resources/commit/cead60cc0b2d28f291f7afb2695282d033587cae)
Thanks in advance.
Re: How to know when IResource.refreshLocal has finished in Oxygen? [message #1768105 is a reply to message #1767952] Thu, 13 July 2017 15:10 Go to previous messageGo to next message
Refresh local does it's work on the calling thread, so when the method returns, it's done. I'm not sure why you need the progress monitor approach?
Re: How to know when IResource.refreshLocal has finished in Oxygen? [message #1768153 is a reply to message #1768105] Fri, 14 July 2017 08:17 Go to previous message
Thanks for your answer Ed.
Whether the refreshLocal is running in the same thread I don't need the progress monitor.
Kind regards.
Previous Topic:Problems invoking selectReveal() on ProjectExplorer view
Next Topic:adding a new VM to installed JRE workbench
Current Time: Tue Jul 07 17:10:35 GMT 2020
Powered by FUDForum. Page generated in 0.01509 seconds
