Home » Modeling » EMF » Name Collision in Package and its elements
Name Collision in Package and its elements [message #1767289] Tue, 04 July 2017 13:09 Go to next message
Ran Wei is currently offline Ran WeiFriend
Recently I ran into a problem which I believe was caused by name collision.
I have a package named Artefact and within this package I have a class called ArtefactPackage (and it needs to be called this). When I generate model codes there are many compilation errors, which I believe was caused by the fact that ArtefactPackage is generated for the Package but Java confuses this with the ArtefactPackage element in the Package.
Is there a way to avoid this, please?
Will
Research Associate
Department of Computer Science
University of York
Re: Name Collision in Package and its elements [message #1767292 is a reply to message #1767289] Tue, 04 July 2017 13:36 Go to previous messageGo to next message
genmodel has quite a few naming options. You can tweak the prefix. You can arrange for the 'meta' classes to be in a distinct Java package so that you really can have two ArtefactPackage classes.
Ed Willink
Re: Name Collision in Package and its elements [message #1767372 is a reply to message #1767292] Wed, 05 July 2017 11:05 Go to previous message
Hi Ed,
Thanks very much! I have found a way around the problem.
Will
Research Associate
University of York
Previous Topic:How to know the name of a class (metadata) in a composition relationhip?
Next Topic:Does EMF supports merge multi-model instance into one, which are based on the same meta-model
Current Time: Mon Jan 27 07:04:51 GMT 2020
Powered by FUDForum. Page generated in 0.02421 seconds
