Home » Eclipse Projects » GEF » GEF5 Node building(Trying to build nodes as words of a sentence)
GEF5 Node building [message #1767070] Fri, 30 June 2017 11:18 Go to next message
Mike Shimko is currently offline Mike ShimkoFriend
Im trying to make such scenario:
1.User enters a sentence in UI and presses a button
2.Sentence is converted to tokens
tokens = str.split(delims);
3.Graph is being created
static Graph createGraph() {
		Builder b = new Graph.Builder();
		addNodes(b,1);
		Graph g = b.build();
		System.out.println(g);
		return g;
addNodes method:
private static void addNodes(Graph.Builder graphBuilder,int startNumber) {
	List<Node> nodes = new ArrayList<>();
	for (int i = 0; i < tokens.length; i++) {
		nodes.add(new Node.Builder().attr(tokens[i], (startNumber + i)).buildNode());
	graphBuilder.nodes(nodes);
4. Graph set to Iviewer
viewer.getContents().setAll(Collections.singletonList(graph));
It does work, however:
1.node names are not displayed ( how to add token as a node name?)
2.all nodes are overlapping eachother ( layoutAlgorithm is missing i guess)
Any ways of correcting my code? Maybe there is other way to build nodes of a graph when sentence size is variable?
UPD: Fixed the overlapping with adding LayoutAlgorithm
.attr(ZestProperties.LAYOUT_ALGORITHM__G,new HorizontalShiftAlgorithm());
UPD 2:
Fixed names using simplier builder for nodes
			b.node(tokens[i]).attr(LABEL, tokens[i]);
		return g;
Case closed :P
[Updated on: Fri, 30 June 2017 12:23]
Report message to a moderator
Re: GEF5 Node building [message #1767076 is a reply to message #1767070] Fri, 30 June 2017 12:23 Go to previous messageGo to next message
Matthias Wienand is currently offline Matthias WienandFriend
Hi Mike,
1) You need to set the correct attribute when creating the nodes, for the label it is ZestProperties#LABEL__NE.
2) You can specify the layout algorithm via the ZestProperties#LAYOUT_ALGORITHM__G attribute.
Simple example:
    public Graph buildForSentence(String sentence) {
        b.attr(ZestProperties.LAYOUT_ALGORITHM__G, new GridLayoutAlgorithm());
        String[] words = sentence.split(" ");
        for (int i = 0; i < words.length; i++) {
            b.node(i).attr(ZestProperties.LABEL__NE, words[i]);
            if (i > 0) {
                b.edge(i - 1, i).attr(ZestProperties.TARGET_DECORATION__E, new Polygon(-10, 0, 0, 5, 0, -5));
        return b.build();
    protected Graph createGraph() {
        String sentence = "The quick brown fox jumps over the lazy dog.";
        return buildForSentence(sentence);
Note that you can assign a key to the nodes during construction, to which you can refer to add edges or attributes later.
Matthias
Re: GEF5 Node building [message #1767081 is a reply to message #1767076] Fri, 30 June 2017 13:08 Go to previous message
Thank you!
Previous Topic:JavaFX + GEF5 + E4 RCP Application troubles
Next Topic:JavaFX + GEF5 + E4 RCP. EventHandling
Current Time: Sun Jun 11 00:12:55 GMT 2023
Powered by FUDForum. Page generated in 0.01591 seconds
