Home » Modeling » Papyrus » <<Trace>> Realization in Palette
<<Trace>> Realization in Palette [message #1766941] Wed, 28 June 2017 21:24 Go to next message
Andreas Graf is currently offline Andreas GrafFriend
Hi all,
I am using the "Standard" UML Profile in order to have the <<Trace>> stereotype on realization. Is there anyway to add to the palette an entry, so that a realization with <<Trace>> is created, in order not to have to set the stereotype explicitely through properties view?
Andreas
Re: <<Trace>> Realization in Palette [message #1767720 is a reply to message #1766941] Mon, 10 July 2017 10:12 Go to previous message
Marc-Florian Wendland is currently offline Marc-Florian WendlandFriend
Member
Sure, there is. You can create your own dedicated palette for exactly those kind of things. Move the mouse onto the palette's area and clickt the right mouse button. There is a context menu entry 'Customize'
Previous Topic:ElementTypeRegistry instance load/reload problem
Next Topic:Load a Papyrus ModelSet programmatically
Current Time: Thu Aug 06 01:31:33 GMT 2020
Powered by FUDForum. Page generated in 0.01503 seconds
