Re: Nothing is being generated [message #1766818 is a reply to message #1766802] |
Tue, 27 June 2017 14:42   |
Hi Geoffry,
This warning is there to tell you that the "plug-in application" choice of the launch configuration is not functional anymore. However, you can still generate code with either the "Java application" choice (see image below) or through the use of a acceleo UI launcher plug-in.
The documentation is not really up-to-date, but you can find information on how to create a UI launcher for Acceleo in the Getting Started guide.
Laurent Goubet
Obeo
Re: Nothing is being generated [message #1767012 is a reply to message #1766997] |
Thu, 29 June 2017 13:58   |
Okay so if I understand correctly you've pointed the "main" class of the Acceleo launch config towards the EMF "Generator" class. Truth be told I didn't even know that was possible.
The "main class" field of your launch configuration needs to be pointed towards an Acceleo generator's main class. This is the java class that's generated beside the ".mtl" file containing a template with the "@main" annotation.
Please look at the "Getting Started" guide on the wiki. though some of the screenshot there need to be reworked, the information should still answer some of your issues and help you get a first generator running.
Laurent Goubet
Obeo
Re: Nothing is being generated [message #1767091 is a reply to message #1767037] |
Fri, 30 June 2017 14:52   |
Your page seems fine to me Tomasz, but we do not intend on linking people to external pages for the acceleo documentation, especially on something like the getting started that is supposed to be a started guide.
Going through the documentation ti try and update the old stuff is in my backlog, so I expect the "regular" getting started (https://wiki.eclipse.org/Acceleo/Getting_Started) to be updated with new screenshots sooner or later. Could you update that page?
Laurent Goubet
Obeo
FUDForum. Page generated in 0.02155 seconds
