Jump links default settings cannot be applied [message #1766662] |
Sat, 24 June 2017 10:08 |
Yves Rambinintsoa Messages: 1 Registered: February 2012 |
Hello to all,
I use currently following Papyrus version (for MS Windows, 64 Bit)
Version: Neon (4.6.0)
Build id: 2017-01-10T18:00:02Z
I have a question: how do I set a default jump link status and type for all connections?
I defined in Papyrus -> Window -> Preferences -> Papyrus -> Diagrams for "jump Links":
- Status: Below
- Type: Square
But each time I create a diagram (e.g. Internal Block Diagram) and make links cross, the "jump link" setting doesn't apply. So I have always to set it manually for each link (click on the connection -> appearance -> Jump links -> change manually Status & Type.
Do I miss something or is this a bug?
FUDForum. Page generated in 0.03208 seconds
