Invalid Thread Access [message #1766607] |
Fri, 23 June 2017 12:29 |
Alexander Kerner Messages: 25 Registered: January 2015 |
I have the following event handler:
public class AssignPAMHandler {
private static final Logger logger = Logger.getLogger(AssignPAMHandler.class);
@Execute
public void execute() {
System.err.println(Thread.currentThread());
showDialog();
private void showDialog() {
Display.getDefault().asyncExec(() -> showDialogSWT());
private void showDialogSWT() {
new JFXPanel(); // initializes JavaFX environment
Platform.runLater(() -> showDialogFX());
private void showDialogFX() {
TextInputDialog dialog = new TextInputDialog("walter");
dialog.setTitle("Text Input Dialog");
dialog.setHeaderText("Look, a Text Input Dialog");
dialog.setContentText("Please enter your name:");
dialog.showAndWait().ifPresent(name -> System.out.println("Your name: " + name));
When I execute this handler via a menu item, I get the following output and exception (the dialog shows up, nevertheless):
Thread[main,6,main]
Thread[main,6,main]
Thread[JavaFX Application Thread,6,main]
Exception in thread "JavaFX Application Thread" org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4533)
at org.eclipse.swt.SWT.error(SWT.java:4448)
at org.eclipse.swt.SWT.error(SWT.java:4419)
at org.eclipse.swt.widgets.Widget.error(Widget.java:483)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:421)
at org.eclipse.swt.widgets.Widget.getData(Widget.java:537)
at org.eclipse.e4.ui.internal.workbench.swt.ShellActivationListener.handleEvent(ShellActivationListener.java:61)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1605)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1339)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1366)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1345)
at org.eclipse.swt.widgets.Shell.filterProc(Shell.java:807)
at org.eclipse.swt.widgets.Display.filterProc(Display.java:1621)
at com.sun.glass.ui.gtk.GtkApplication.enterNestedEventLoopImpl(Native Method)
at com.sun.glass.ui.gtk.GtkApplication._enterNestedEventLoop(GtkApplication.java:211)
at com.sun.glass.ui.Application.enterNestedEventLoop(Application.java:511)
at com.sun.glass.ui.EventLoop.enter(EventLoop.java:107)
at com.sun.javafx.tk.quantum.QuantumToolkit.enterNestedEventLoop(QuantumToolkit.java:583)
at javafx.stage.Stage.showAndWait(Stage.java:474)
at javafx.scene.control.HeavyweightDialog.showAndWait(HeavyweightDialog.java:162)
at javafx.scene.control.Dialog.showAndWait(Dialog.java:341)
at net.openchrom.chromatogram.xxd.identifier.supplier.chromident.ui.handler.AssignPAMHandler.showDialogFX(AssignPAMHandler.java:54)
The executing thread seems to be the same all the time and the FX dialog shows up. Nevertheless, the exception is thrown.
FUDForum. Page generated in 0.01904 seconds
