Home » Newcomers » Newcomers » Could not write metadata for '/'(Error appears sporadically)
Could not write metadata for '/' [message #1766540] Thu, 22 June 2017 19:31 Go to next message
Mike Gilmer is currently offline Mike GilmerFriend
The error
appears every few minutes while using Eclipse.
Could someone please tell me
1) What the metadata is for
2) how to get rid of the error
I've looked through these forums but have not found an answer.
Thanks for your time.
Mike
Re: Could not write metadata for '/' [message #1766642 is a reply to message #1766540] Fri, 23 June 2017 18:26 Go to previous messageGo to next message
What is your workspace location? You shouldn't use the root of a file system for the workspace location...
Ed Merks
Re: Could not write metadata for '/' [message #1766718 is a reply to message #1766642] Mon, 26 June 2017 13:33 Go to previous messageGo to next message
The workspace is at home/<myusername>/workspace - or at least it should be.
Where in the setting for Eclipse can I verify what Eclipse thinks the workspace is?
[Updated on: Mon, 26 June 2017 13:34]
Report message to a moderator
Re: Could not write metadata for '/' [message #1766809 is a reply to message #1766718] Tue, 27 June 2017 13:21 Go to previous message
If you do File -> Switch Workspace -> Other... it will show your current workspace and you can open a new one in a different location, switching to that.
Ed Merks
Previous Topic:org.eclipse.birt.report.data.oda.jdbc.JndiDataSource getDriverJndiPropertyFile
Next Topic:Cannot find "paths and symbols" under the tag of C/C++ General in project property
Current Time: Mon Mar 01 05:04:54 GMT 2021
Powered by FUDForum. Page generated in 0.02854 seconds
