Home » Modeling » QVT-OML » EMF to EMF Transformation(Creating custom EClass objects)
EMF to EMF Transformation [message #1766391] Wed, 21 June 2017 00:17 Go to next message
Ruben Mathew is currently offline Ruben MathewFriend
I would be grateful if you can help me figure out how to do an EMF to EMF transformation,
a)The core question is how to copy Class A into Class B, C and D inside the EPackage Declaration.
b) for some reason the EMF to UML (mapping is unavailable in Neon, no uml in uses dropdown list options). Since I didn't have time to figure out why, I decided to just go with EMF.
c) Just in case you have time, can you tell me why my copy of EMF Gen file is starting with XMI root instead of EPackage Root ?
TIA !
Ruben.
Re: EMF to EMF Transformation [message #1766920 is a reply to message #1766391] Wed, 28 June 2017 18:03 Go to previous message
a) any respectable M2M tool should work
b) that is perhaps the worst reason ever for using EMF
c) perhaps there are multiple root elements. Even a single root may still use an XMI root.
Ed Willink
Previous Topic:apply stereotype on element Problem!
Next Topic:How to trigger XMI transformation in programed java
Current Time: Wed Dec 11 20:50:11 GMT 2019
Powered by FUDForum. Page generated in 0.02205 seconds
