Home » Eclipse Projects » Lyo » Update DNG Module Artifact attributes(Update DNG Module Artifact attributes)
Update DNG Module Artifact attributes [message #1766250] Mon, 19 June 2017 11:48 Go to next message
Rajkumar K is currently offline Rajkumar KFriend
I am currently evaluating the Eclipse Lyo for my Requirement. My requirement is I have a project Area in DNG where I have to update the artifact's link (ex: Satisfied By, Satisfies) in the Module.
Please let me know whether is it possible to implement such a use case in Eclipse Lyo. If so where I can find examples and sources.
Thank you,
Best regards
Rajkumar
Re: Update DNG Module Artifact attributes [message #1766253 is a reply to message #1766250] Mon, 19 June 2017 13:08 Go to previous messageGo to next message
Jim Amsden is currently offline Jim AmsdenFriend
Yes, this should be possible using eclipse/Lyo. There's an example in: org.eclipse.lyo.client/org.eclipse.lyo.client.java.sample/src/main/java/org/eclipse/lyo/client/oslc/samples/RRCFormSample.java that should be helpful.
Re: Update DNG Module Artifact attributes [message #1766333 is a reply to message #1766253] Tue, 20 June 2017 11:07 Go to previous message
Many thanks for your support. I will try this :)
Thank you,
Best Regards,
Rajkumar
Previous Topic:OSLC resource type generator?
Next Topic:Issue with Lyo Code Generator & Toolchain installation
Current Time: Tue Jan 21 12:12:41 GMT 2020
Powered by FUDForum. Page generated in 0.02024 seconds
