Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF to USE
EMF to USE [message #1765457] Fri, 09 June 2017 17:19 Go to next message
Banafsheh Azizi is currently offline Banafsheh AziziFriend
How can I translate EMF to USE format?
Member of MDSE Research Group
http://mdse.ui.ac.ir
Re: EMF to USE [message #1765459 is a reply to message #1765457] Fri, 09 June 2017 17:38 Go to previous messageGo to next message
If by USE you mean https://sourceforge.net/projects/useocl/ I suggest you read the USE documentation.
Since USE is for UML, you might try the Ecore2UML menu entry.
For OCL aspects ask what you want to know more precisely on the OCL newsgroup.
Ed Willink
Re: EMF to USE [message #1766312 is a reply to message #1765459] Tue, 20 June 2017 08:01 Go to previous messageGo to next message
Ed Willink wrote on Fri, 09 June 2017 17:38
I installed Ecore tools. However, I cannot see Ecore2UML menu entry when I right clicked on .ecore file.
Re: EMF to USE [message #1766318 is a reply to message #1766312] Tue, 20 June 2017 08:18 Go to previous messageGo to next message
It's in the Sample Ecore Editor toolbar menu.
You need to select an EPackage to avoid the "Convert to UML model..." being greyed out.
Ed Willink
Re: EMF to USE [message #1766506 is a reply to message #1766318] Thu, 22 June 2017 10:47 Go to previous messageGo to next message
Thank you very much indeed.
Unfortunately, USE just know its format such the bellow code and doesn't support the uml.
model Person
class Person
attributes
  age : Integer
end
association Family between
  Person[1] role father
  Person[1] role mother
  Person[*] role child
end
Re: EMF to USE [message #1766533 is a reply to message #1766506] Thu, 22 June 2017 18:19 Go to previous message
If you're lucky that might be compatible with TextUML. More l;ikley you need to write custom Ecore2USE M2T. Pretty easier.
Ed Willink
Previous Topic:[EMF Forms] Ecore and Genmodel editor issues
Next Topic:distinguish between EClasses
Current Time: Sat May 21 07:17:01 GMT 2022
Powered by FUDForum. Page generated in 0.01757 seconds
