Home » Modeling » OCL » Negation of OCL expressions
Negation of OCL expressions [message #1765430] Fri, 09 June 2017 11:52 Go to next message
meriem lahr is currently offline meriem lahrFriend
Member
Hi all,
I'm working on the adaptation of OCL constraints associated to a metamodel and i need to generate the negation of these expressions as an initial phase. Is there a way to automatically get these negations?
Meriem
[Updated on: Fri, 09 June 2017 11:56]
Report message to a moderator
Re: Negation of OCL expressions [message #1765434 is a reply to message #1765430] Fri, 09 June 2017 12:46 Go to previous message
You question doesn't really make any sense. No idea what an initial phase is.
There are normally many context/constraint permutations for which only are values are false; negating would give you numerous results.
You can of course just use "not".
If you use the Validity View you can see any context/constraint permutations and so look at the inverses.
Ed Willink
Previous Topic:Possible problems with implicit properties of Stereotypes
Next Topic:Using Java APIs
Current Time: Tue Jan 28 08:00:04 GMT 2020
Powered by FUDForum. Page generated in 0.02410 seconds
