Home » Modeling » TMF (Xtext) » manage eopposite references coming from imported metamodel
manage eopposite references coming from imported metamodel [message #1765199] Wed, 07 June 2017 13:13 Go to next message
Fy Za is currently offline Fy ZaFriend
Hi everybody,
I have this metamodel
index.php/fa/29579/0/
I create a Xtext grammar from this metamodel
// automatically generated by Xtext
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
import "http://www.xtext.org/example/mydsl/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model returns Model:
	{Model}
	'Model'
	name=ID
		('classAs' '{' classAs+=ClassA ( "," classAs+=ClassA)* '}' )?
ClassA returns ClassA:
	{ClassA}
	'ClassA'
	name=ID
	//	('referingbs' '(' referingbs+=[ClassB|ID] ( "," referingbs+=[ClassB|ID])* ')' )?
		('classb' '{' classb+=ClassB ( "," classb+=ClassB)* '}' )?
ClassB returns ClassB:
	'ClassB'
	name=ID
		'target' target=[ClassA|ID]
My models are saved as XMI using a mechanism described in previous posts (That is not the issue).
The problem comes from the "referingbs" reference which is an eopposite reference to "target" reference.
When I create a model containing an instance of ClassB that refers to ClassA instance via target reference,
Xtext throws an error
java.lang.RuntimeException: Could not serialize ClassA:
ClassA.referingbs violates the upper bound: It holds 1 values, but only 0 are allowed.
Semantic Object: Model'model1'.classAs[0]->ClassA'class1'
URI: temp.my
Context: ClassA returns ClassA
	at org.eclipse.xtext.serializer.diagnostic.ISerializationDiagnostic$ExceptionThrowingAcceptor.accept(ISerializationDiagnostic.java:131)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:503)
	at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence_ClassA(MyDslSemanticSequencer.java:59)
	at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence(MyDslSemanticSequencer.java:38)
	at org.eclipse.xtext.serializer.sequencer.AbstractSemanticSequencer.createSequence(AbstractSemanticSequencer.java:67)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptEObjectRuleCall(SequenceFeeder.java:325)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptRuleCall(SequenceFeeder.java:352)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:263)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:434)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:501)
	at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence_Model(MyDslSemanticSequencer.java:92)
	at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence(MyDslSemanticSequencer.java:44)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:115)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:128)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:192)
	at org.eclipse.xtext.resource.XtextResource.doSave(XtextResource.java:386)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1430)
I found this message https://www.eclipse.org/forums/index.php?t=msg&th=1079030&goto=1737136&#msg_1737136
that proposes to customize ITransientValueService feature.
I customize it by adding the following
class MyDslRuntimeModule extends AbstractMyDslRuntimeModule {
	def Class<? extends LegacyTransientValueService> bindITransientValueService2() {
		MyDslTransientValueService
public class MyDslTransientValueService extends LegacyTransientValueService {
	public ValueTransient isValueTransient(EObject semanticObject, EStructuralFeature feature) {
		if (feature == MyDslPackage.Literals.CLASS_A__REFERINGBS) {
			return ValueTransient.YES;
		return super.isValueTransient(semanticObject, feature);
However the original error always appears (ClassA.referingbs violates the upper bound: It holds 1 values, but only 0 are allowed).
My question: how can I resolve this eopposite issue in Xtext?
I share the complete case-study containing an example (in the org.eclipse.example.mydsl.example project)
if someone is interested to reproduce.
best regards
Re: manage eopposite references coming from imported metamodel [message #1765223 is a reply to message #1765199] Wed, 07 June 2017 16:08 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
does this unittest reproduce your problem?
package org.xtext.example.mydsl.tests
import com.google.inject.Inject
import com.google.inject.Provider
import org.eclipse.emf.common.util.URI
import org.eclipse.emf.ecore.resource.ResourceSet
import org.eclipse.xtext.serializer.ISerializer
import org.eclipse.xtext.testing.InjectWith
import org.eclipse.xtext.testing.XtextRunner
import org.junit.Test
import org.junit.runner.RunWith
import myDsl.MyDslFactory
@RunWith(XtextRunner)
@InjectWith(MyDslInjectorProvider)
class MyDslParsingTest {
	@Inject
	extension ISerializer ser
	@Inject Provider<ResourceSet> rsp
	@Test
	def void loadModel() {
		val rs = rsp.get
		val r = rs.createResource(URI.createURI("dummy.my"))
		val m = MyDslFactory.eINSTANCE.createModel => [
			name = "m"
			val a = MyDslFactory.eINSTANCE.createClassA => [
				name = "a"
			val b = MyDslFactory.eINSTANCE.createClassB => [
				name = "b"
			classAs += a
			a.classb += b
			b.target = a
		r.contents += m
		println(m.serialize)
Twitter : @chrdietrich
Re: manage eopposite references coming from imported metamodel [message #1765224 is a reply to message #1765223] Wed, 07 June 2017 16:11 Go to previous messageGo to next message
Thank you Chrisitan for reply
The test shows the same error
Semantic Object: Model'm'.classAs[0]->ClassA'a'
URI: dummy.my
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:178)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:55)
	at org.xtext.example.mydsl.tests.MyDslParsingTest.loadModel(MyDslParsingTest.java:62)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
	at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
	at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
	at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
	at org.eclipse.xtext.testing.XtextRunner$1.evaluate(XtextRunner.java:49)
	at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:678)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
[Updated on: Wed, 07 June 2017 16:13]
Report message to a moderator
Re: manage eopposite references coming from imported metamodel [message #1765226 is a reply to message #1765224] Wed, 07 June 2017 16:25 Go to previous messageGo to next message
public ListTransient isListTransient(EObject semanticObject, EStructuralFeature feature) {
return ListTransient.YES;
return super.isListTransient(semanticObject, feature);
Re: manage eopposite references coming from imported metamodel [message #1765232 is a reply to message #1765224] Wed, 07 June 2017 17:17 Go to previous messageGo to next message
Thank you Christian.
[Updated on: Wed, 07 June 2017 20:21]
Re: manage eopposite references coming from imported metamodel [message #1765246 is a reply to message #1765232] Wed, 07 June 2017 20:29 Go to previous messageGo to next message
A new error appears now :( .
I create this EMF model
<myDsl:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:myDsl="http://www.xtext.org/example/mydsl/MyDsl" name="model1">
  <classAs name="classa1" referingbs="//@classAs.0/@classb.0">
    <classb name="classb1" target="//@classAs.0"/>
  </classAs>
</myDsl:Model>
I open it with the textual editor.
It shows this model
Model model1 { classAs { ClassA classa1 { classb { ClassB classb1 { target classa1 } } } } }
When I edit the textual model (just add white space and save),
the xmi becomes
  <classAs name="classa1">
  </classAs>
</myDsl:Model>
The reference referingbs="//@classAs.0/@classb.0" is removed.
And this error appears
java.lang.RuntimeException: A value for feature 'target' is missing but required.
Semantic Object: Model'model1'.classAs[0]->ClassA'classa1'.classb[0]->ClassB'classb1'
URI: temp.my
	at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence_ClassB(MyDslSemanticSequencer.java:75)
	at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence(MyDslSemanticSequencer.java:41)
	at org.xtext.example.mydsl.ui.MyDslDocumentProvider.setDocumentContent(MyDslDocumentProvider.java:57)
	at org.eclipse.ui.editors.text.FileDocumentProvider.setDocumentContent(FileDocumentProvider.java:425)
	at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.setDocumentContent(XtextDocumentProvider.java:183)
	at org.eclipse.ui.editors.text.FileDocumentProvider.handleElementContentChanged(FileDocumentProvider.java:814)
	at org.eclipse.ui.editors.text.FileDocumentProvider.doSynchronize(FileDocumentProvider.java:526)
	at org.eclipse.ui.texteditor.AbstractDocumentProvider$1SynchronizeOperation.execute(AbstractDocumentProvider.java:951)
	at org.eclipse.ui.texteditor.AbstractDocumentProvider$DocumentProviderOperation.run(AbstractDocumentProvider.java:72)
	at org.eclipse.ui.actions.WorkspaceModifyDelegatingOperation.execute(WorkspaceModifyDelegatingOperation.java:67)
	at org.eclipse.ui.actions.WorkspaceModifyOperation.lambda$0(WorkspaceModifyOperation.java:107)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
	at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:128)
	at org.eclipse.ui.internal.editors.text.WorkspaceOperationRunner.run(WorkspaceOperationRunner.java:73)
	at org.eclipse.ui.internal.editors.text.WorkspaceOperationRunner.run(WorkspaceOperationRunner.java:63)
	at org.eclipse.ui.texteditor.AbstractDocumentProvider.executeOperation(AbstractDocumentProvider.java:536)
	at org.eclipse.ui.texteditor.AbstractDocumentProvider.synchronize(AbstractDocumentProvider.java:960)
	at org.eclipse.ui.texteditor.AbstractTextEditor.handleEditorInputChanged(AbstractTextEditor.java:4730)
	at org.eclipse.ui.texteditor.StatusTextEditor.handleEditorInputChanged(StatusTextEditor.java:252)
	at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.handleEditorInputChanged(AbstractDecoratedTextEditor.java:1485)
	at org.eclipse.ui.texteditor.AbstractTextEditor.sanityCheckState(AbstractTextEditor.java:4870)
	at org.eclipse.ui.texteditor.StatusTextEditor.sanityCheckState(StatusTextEditor.java:245)
	at org.eclipse.ui.texteditor.AbstractTextEditor.safelySanityCheckState(AbstractTextEditor.java:4848)
	at org.eclipse.ui.texteditor.AbstractTextEditor$ActivationListener.handleActivation(AbstractTextEditor.java:961)
	at org.eclipse.ui.texteditor.AbstractTextEditor$ActivationListener.partActivated(AbstractTextEditor.java:926)
	at org.eclipse.ui.internal.PartService$1.run(PartService.java:84)
	at org.eclipse.ui.internal.PartService.partActivated(PartService.java:81)
	at org.eclipse.ui.internal.WorkbenchWindow$WWinPartService.partActivated(WorkbenchWindow.java:3002)
	at org.eclipse.ui.internal.WorkbenchPage$14.run(WorkbenchPage.java:4977)
	at org.eclipse.ui.internal.WorkbenchPage.firePartActivated(WorkbenchPage.java:4974)
	at org.eclipse.ui.internal.WorkbenchPage.access$19(WorkbenchPage.java:4962)
	at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:210)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$3.run(PartServiceImpl.java:250)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:247)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:757)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:682)
	at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:95)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:63)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4256)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1501)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1524)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1509)
	at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1612)
	at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1575)
	at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java:3428)
	at org.eclipse.swt.widgets.Canvas.sendFocusEvent(Canvas.java:76)
	at org.eclipse.swt.widgets.Display.checkFocus(Display.java:672)
	at org.eclipse.swt.widgets.Shell.makeFirstResponder(Shell.java:1294)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5843)
	at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
	at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:227)
	at org.eclipse.swt.widgets.Widget.windowSendEvent(Widget.java:2140)
	at org.eclipse.swt.widgets.Shell.windowSendEvent(Shell.java:2402)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5797)
	at org.eclipse.swt.widgets.Display.applicationSendEvent(Display.java:5226)
	at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5375)
	at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
	at org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApplication.java:128)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3703)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Please any suggestion/idea?
best
Re: manage eopposite references coming from imported metamodel [message #1765247 is a reply to message #1765246] Wed, 07 June 2017 20:33 Go to previous messageGo to next message
No you have ask ed. Did you have a look at the model before saving to xmi
Is it ok are both refs set. Afaik you have to do this manually right?
Re: manage eopposite references coming from imported metamodel [message #1765249 is a reply to message #1765247] Wed, 07 June 2017 20:38 Go to previous messageGo to next message
So to say: is the model correct after Xtext (re)parsed it
Another thing for a simple unit test
And I have a dejavue feeling that you already had solved this a week ago
[Updated on: Wed, 07 June 2017 20:45]
Re: manage eopposite references coming from imported metamodel [message #1765251 is a reply to message #1765249] Wed, 07 June 2017 20:47 Go to previous messageGo to next message
the re-parsed model doesn't show errors but a wizard appears showing the error.
Christian, the attachment shows a demo explaining the complete scenario
Re: manage eopposite references coming from imported metamodel [message #1765255 is a reply to message #1765251] Wed, 07 June 2017 21:01 Go to previous messageGo to next message
no i meant this
import myDsl.Model
import org.eclipse.xtext.testing.util.ParseHelper
import org.junit.Assert
	@Inject
	ParseHelper<Model> parseHelper
	@Test
		val result = parseHelper.parse('''
		Assert.assertNotNull(result)
		Assert.assertTrue(result.eResource.errors.isEmpty)
		println(result.classAs.head.referingbs)
Re: manage eopposite references coming from imported metamodel [message #1765258 is a reply to message #1765255] Wed, 07 June 2017 21:05 Go to previous messageGo to next message
The test is correct.
However, the println shows
Re: manage eopposite references coming from imported metamodel [message #1765260 is a reply to message #1765258] Wed, 07 June 2017 21:07 Go to previous messageGo to next message
yes and this means the test is not correct, it should print the b right?
Re: manage eopposite references coming from imported metamodel [message #1765262 is a reply to message #1765260] Wed, 07 June 2017 21:09 Go to previous messageGo to next message
Yes. it should print the classb1 object
Re: manage eopposite references coming from imported metamodel [message #1765263 is a reply to message #1765262] Wed, 07 June 2017 21:23 Go to previous messageGo to next message
and i thought we were already at this point 2 weeks ago with the fsm stuff.
class MyDslDerivedStateComputer implements IDerivedStateComputer {
	override discardDerivedState(DerivedStateAwareResource resource) {
		if (!resource.contents.empty) {
			val model = resource.contents.head as Model
			for (a : model.classAs) {
				a.referingbs.clear
	override installDerivedState(DerivedStateAwareResource resource, boolean preLinkingPhase) {
				println(a.name)
				for (ai : model.classAs) {
					for (bi : ai.classb) {
						val name = NodeModelUtils.findNodesForFeature(bi, MyDslPackage.Literals.CLASS_B__TARGET).head?.text?.trim
						println(name)
						if (a.name == name) {
							println("found")
							val EObject proxy = EcoreUtil.create(MyDslPackage.Literals.CLASS_B)							(proxy as InternalEObject).eSetProxyURI(EcoreUtil.getURI(a));
							(proxy as InternalEObject).eSetProxyURI(EcoreUtil.getURI(bi))
							a.referingbs += proxy as ClassB
(dont know how this stuff will behave cross file, maybe you need another approach for that - maybe ed can help)
Re: manage eopposite references coming from imported metamodel [message #1765264 is a reply to message #1765263] Wed, 07 June 2017 21:35 Go to previous messageGo to next message
Yes Christian, but in the fsm stuff, the first part MyDslTransientValueService misses
what do you mean when you say "cross file"?
Re: manage eopposite references coming from imported metamodel [message #1765268 is a reply to message #1765264] Wed, 07 June 2017 21:52 Go to previous message
If b and a are in a different file you cannot search matching a and bs the way I do
Previous Topic:import and scope provider
Next Topic:An internal error occurred during: "calculating highlighting".
Current Time: Mon Sep 25 08:12:08 GMT 2023
Powered by FUDForum. Page generated in 0.02982 seconds
