Home » Modeling » TMF (Xtext) » Priority/Order of contentassist proposals (in particular templates)
Priority/Order of contentassist proposals (in particular templates) [message #1765073] Tue, 06 June 2017 11:46 Go to next message
Lukas Schaus is currently offline Lukas SchausFriend
Member
I developed a DSL Using XText 2.11.
My Problem is that the content assisst orders the proposals in an order that is not satisfactory for my application.
There are three different kinds of Proposals in my Language
  • Proposals that I defined in a ProposalProvider
  • Automatically generated Proposals based on my grammar
  • Templates from templates.xml
The proposals appear in that order. I would like to see the Template proposals at the top of the proposal list.
How can that be achieved?
Thank you
Lukas
Re: Priority/Order of contentassist proposals (in particular templates) [message #1765078 is a reply to message #1765073] Tue, 06 June 2017 12:24 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
have a look at org.eclipse.xtext.ui.editor.templates.DefaultTemplateProposalProvider.getRelevance(Template)
Twitter : @chrdietrich
Re: Priority/Order of contentassist proposals (in particular templates) [message #1765428 is a reply to message #1765078] Fri, 09 June 2017 11:48 Go to previous messageGo to next message
Member
Thank you for your quick reply.
I have tried to override the method you pointed me at. But I am having trouble.
This is what i did:
In the ui project i have created a new package ui.templates and a new xtend class MrsLangTemplateProposalProvider.xtend with the following content:
class MrsLangTemplateProposalProvider extends DefaultTemplateProposalProvider {
	new(TemplateStore templateStore, ContextTypeRegistry registry, ContextTypeIdHelper helper) {
		super(templateStore, registry, helper)
	override getRelevance(Template template) {
		return 1
Additionally i tried to bind this class by adding the following code to the UIModule.xtend in th ui package:
@FinalFieldsConstructor
class MrsLangUiModule extends AbstractMrsLangUiModule {
	def Class<? extends AbstractTemplateProposalProvider> bindAbstractTemplateProposalProvider () {
I am not very familiar with the Binding mechanism. It would be very helpful if you could point me in the right direction.
Additionally i was wondering weather a low number indicates a high relevance or not.
Thank you in advance
Lukas
Re: Priority/Order of contentassist proposals (in particular templates) [message #1765431 is a reply to message #1765428] Fri, 09 June 2017 12:01 Go to previous messageGo to next message
override Class<? extends ITemplateProposalProvider> bindITemplateProposalProvider() {
return TemplateProposalProvider
Re: Priority/Order of contentassist proposals (in particular templates) [message #1765559 is a reply to message #1765431] Mon, 12 June 2017 13:12 Go to previous messageGo to next message
Member
Thank you for the clarification on the binding part, but i still dont get it right. When I start the plugin i get the following Errors:
0    [main] ERROR com.modelengineers.mrsl.ui.internal.MrslActivator  - Failed to create injector for com.modelengineers.mrsl.MrsLang
7    [main] ERROR com.modelengineers.mrsl.ui.internal.MrslActivator  - Guice creation errors:
1) No implementation for com.modelengineers.mrsl.ui.templates.MrsLangTemplateProposalProvider was bound.
  at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:57)
1 error
com.google.inject.CreationException: Guice creation errors:
1 error
	at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:435)
	at com.google.inject.internal.InternalInjectorCreator.initializeStatically(InternalInjectorCreator.java:154)
	at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:106)
	at com.google.inject.Guice.createInjector(Guice.java:95)
	at com.google.inject.Guice.createInjector(Guice.java:72)
	at com.google.inject.Guice.createInjector(Guice.java:62)
	at com.modelengineers.mrsl.ui.internal.MrslActivator.createInjector(MrslActivator.java:67)
	at com.modelengineers.mrsl.ui.internal.MrslActivator.getInjector(MrslActivator.java:55)
	at com.modelengineers.mrsl.ui.MrsLangExecutableExtensionFactory.getInjector(MrsLangExecutableExtensionFactory.java:24)
	at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:51)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:291)
	at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:286)
	at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:329)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:278)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:63)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:316)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1317)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:103)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:669)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:70)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:665)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:536)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:520)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:70)
	at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:142)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:63)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:725)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1059)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
16   [main] ERROR com.modelengineers.mrsl.ui.MrsLangExecutableExtensionFactory  - Failed to create injector for com.modelengineers.mrsl.MrsLang
java.lang.RuntimeException: Failed to create injector for com.modelengineers.mrsl.MrsLang
	at com.modelengineers.mrsl.ui.internal.MrslActivator.createInjector(MrslActivator.java:71)
Caused by: com.google.inject.CreationException: Guice creation errors:
1 error
	... 135 more
15:04:06.529 [Worker-0] INFO  c.g.t.t.d.PublishedGradleVersions - Gradle version information cache is up-to-date. Trying to read.
1932 [Worker-1] ERROR com.modelengineers.mrsl.ui.internal.MrslActivator  - Failed to create injector for com.modelengineers.mrsl.MrsLang
1936 [Worker-1] ERROR com.modelengineers.mrsl.ui.internal.MrslActivator  - Guice creation errors:
1 error
1 error
	at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.getExtension(ResourceServiceProviderDescriptor.java:46)
	at org.eclipse.xtext.internal.AbstractResourceServiceProviderDescriptor.get(AbstractResourceServiceProviderDescriptor.java:20)
	at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl$InternalData.getServiceProvider(ResourceServiceProviderRegistryImpl.java:46)
	at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:109)
	at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:129)
	at org.eclipse.xtext.ui.resource.UriValidator.isValid(UriValidator.java:27)
	at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.isValidUri(Storage2UriMapperImpl.java:247)
	at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.getUri(Storage2UriMapperImpl.java:233)
	at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.getUri(ToBeBuiltComputer.java:345)
	at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.updateStorage(ToBeBuiltComputer.java:287)
	at org.eclipse.xtext.builder.impl.ToBeBuiltComputer$2.visit(ToBeBuiltComputer.java:260)
	at org.eclipse.core.internal.resources.Resource$2.visit(Resource.java:120)
	at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:84)
	at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82)
	at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:87)
	at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:129)
	at org.eclipse.core.internal.resources.Resource.accept(Resource.java:94)
	at org.eclipse.core.internal.resources.Resource.accept(Resource.java:52)
	at org.eclipse.core.internal.resources.Resource.accept(Resource.java:117)
	at org.eclipse.core.internal.resources.Resource.accept(Resource.java:105)
	at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.updateProject(ToBeBuiltComputer.java:254)
	at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.updateProjectNewResourcesOnly(ToBeBuiltComputer.java:221)
	at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:317)
	at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:155)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:735)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:330)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:405)
	at org.eclipse.core.internal.resources.Project$1.run(Project.java:551)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
	at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:529)
	at org.eclipse.core.internal.resources.Project.build(Project.java:120)
	at org.eclipse.xtext.builder.impl.BuildScheduler$BuildJob.run(BuildScheduler.java:164)
1939 [Worker-1] ERROR com.modelengineers.mrsl.ui.MrsLangExecutableExtensionFactory  - Failed to create injector for com.modelengineers.mrsl.MrsLang
1 error
	... 41 more
1951 [Worker-1] ERROR org.eclipse.xtext.internal.ResourceServiceProviderDescriptor  - Failed to create injector for com.modelengineers.mrsl.MrsLang ExtensionFactory: com.modelengineers.mrsl.ui.MrsLangExecutableExtensionFactory
org.eclipse.core.runtime.CoreException: Failed to create injector for com.modelengineers.mrsl.MrsLang ExtensionFactory: com.modelengineers.mrsl.ui.MrsLangExecutableExtensionFactory
	at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:59)
Caused by: java.lang.RuntimeException: Failed to create injector for com.modelengineers.mrsl.MrsLang
	... 38 more
1 error
	... 41 more
1976 [Worker-1] ERROR org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl  - Erroneous resource service provider registered for 'platform:/resource/Presentation/src/defines.mrsl'. Removing it from the registry.
java.lang.ClassCastException: The type null is not a valid interface org.eclipse.xtext.resource.IResourceServiceProvider or interface org.eclipse.xtext.resource.IResourceServiceProvider$Provider contributed by com.modelengineers.mrsl.ui[547]
	at org.eclipse.xtext.internal.AbstractResourceServiceProviderDescriptor.get(AbstractResourceServiceProviderDescriptor.java:35)
Re: Priority/Order of contentassist proposals (in particular templates) [message #1765561 is a reply to message #1765559] Mon, 12 June 2017 13:16 Go to previous messageGo to next message
can you please share a complete example
Re: Priority/Order of contentassist proposals (in particular templates) [message #1765658 is a reply to message #1765561] Tue, 13 June 2017 08:13 Go to previous messageGo to next message
Member
Sure. I hope this is what you ment when you asked for a complete example:
MrsLangUiModule.xtend
package ....mrsl.ui
import ....mrsl.ui.syntaxColoring.MrsLanguageAntlrTokenToAttributeIdMapper
import ....mrsl.ui.syntaxColoring.MrsLanguageHighlightingConfiguration
import ....mrsl.ui.syntaxColoring.MrsLanguageSemanticHighlightingCalculator
import org.eclipse.xtend.lib.annotations.FinalFieldsConstructor
import org.eclipse.xtext.ide.editor.syntaxcoloring.AbstractAntlrTokenToAttributeIdMapper
import org.eclipse.xtext.ide.editor.syntaxcoloring.ISemanticHighlightingCalculator
import org.eclipse.xtext.ui.editor.syntaxcoloring.IHighlightingConfiguration
import ....modelengineers.mrsl.ui.templates.MrsLangTemplateProposalProvider
import org.eclipse.xtext.ui.editor.contentassist.ITemplateProposalProvider
 * Use this class to register components to be used within the Eclipse IDE.
	def Class<? extends AbstractAntlrTokenToAttributeIdMapper> bindAbstractAntlrTokenToAttributeIdMapper() {
	def Class<? extends IHighlightingConfiguration> bindIHighlightingConfiguration () {
	def Class<? extends ISemanticHighlightingCalculator> bindISemanticHighlightingCalculator () {
		return MrsLangTemplateProposalProvider
MrslangTemplateproposalProvider.xtend
package ....mrsl.ui.templates
import org.eclipse.jface.text.templates.Template
import org.eclipse.xtext.ui.editor.templates.DefaultTemplateProposalProvider
import org.eclipse.jface.text.templates.persistence.TemplateStore
import org.eclipse.jface.text.templates.ContextTypeRegistry
import org.eclipse.xtext.ui.editor.templates.ContextTypeIdHelper
abstract class MrsLangTemplateProposalProvider extends DefaultTemplateProposalProvider {
		return 1
The error that i get when starting the plugin is the same as I posted above.
Greets Lukas
Re: Priority/Order of contentassist proposals (in particular templates) [message #1765660 is a reply to message #1765658] Tue, 13 June 2017 08:23 Go to previous messageGo to next message
lol
what does the abstract do there
Re: Priority/Order of contentassist proposals (in particular templates) [message #1765664 is a reply to message #1765660] Tue, 13 June 2017 08:33 Go to previous messageGo to next message
Member
Christian Dietrich wrote on Tue, 13 June 2017 08:23
lol
Damn. This was one of my desperate approaches to fix this. I removed the abstract and the error is now different:
I dont know how to handle the issue with the contructor.
1) Could not find a suitable constructor in com.modelengineers.mrsl.ui.templates.MrsLangTemplateProposalProvider. Classes must have either one (and only one) constructor annotated with @Inject or a zero-argument constructor that is not private.
  at com.modelengineers.mrsl.ui.templates.MrsLangTemplateProposalProvider.class(Unknown Source)
1 error
1 error
15   [main] ERROR com.modelengineers.mrsl.ui.MrsLangExecutableExtensionFactory  - Failed to create injector for com.modelengineers.mrsl.MrsLang
1 error
	... 135 more
10:27:43.637 [Worker-0] INFO  c.g.t.t.d.PublishedGradleVersions - Gradle version information cache is up-to-date. Trying to read.
1478 [Worker-2] ERROR com.modelengineers.mrsl.ui.internal.MrslActivator  - Failed to create injector for com.modelengineers.mrsl.MrsLang
1517 [Worker-2] ERROR com.modelengineers.mrsl.ui.internal.MrslActivator  - Guice creation errors:
1 error
1 error
1525 [Worker-2] ERROR com.modelengineers.mrsl.ui.MrsLangExecutableExtensionFactory  - Failed to create injector for com.modelengineers.mrsl.MrsLang
1 error
	... 41 more
1527 [Worker-2] ERROR org.eclipse.xtext.internal.ResourceServiceProviderDescriptor  - Failed to create injector for com.modelengineers.mrsl.MrsLang ExtensionFactory: com.modelengineers.mrsl.ui.MrsLangExecutableExtensionFactory
	... 38 more
1 error
	... 41 more
1535 [Worker-2] ERROR org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl  - Erroneous resource service provider registered for 'platform:/resource/Presentation/src/defines.mrsl'. Removing it from the registry.
Re: Priority/Order of contentassist proposals (in particular templates) [message #1765666 is a reply to message #1765664] Tue, 13 June 2017 08:36 Go to previous messageGo to next message
very same
@Inject
Re: Priority/Order of contentassist proposals (in particular templates) [message #1765667 is a reply to message #1765666] Tue, 13 June 2017 08:39 Go to previous message
Member
Oh ja. As it was written in the error message. Thanks and sorry for my inability to read.
For everyone who wants to implement the same: The relevance must be a high number in order to be at the top of the list.
Greets.
Previous Topic:Using an Xbase subset
Next Topic:Attach source code to plug-in: Modeling Workflow Engine 2 Launch
Current Time: Tue Oct 03 21:12:50 GMT 2023
Powered by FUDForum. Page generated in 0.02591 seconds
