Home » Eclipse Projects » Lyo » OSLC resource type generator?(OSLC resource type generator?)
OSLC resource type generator? [message #1765026] Mon, 05 June 2017 19:42 Go to next message
Matt Stone is currently offline Matt StoneFriend
Member
Are there any tools out there that can automatically generate a OSLC base resource type for you? For example the Bugzilla src has a ChangeRequest object that extends AbstractResource and there are other objects like Requirement and RequirementCollection extend the same. But its very tedious creating OSLC resource type classes which don't exists in the Lyo codebase. It would be nice if there was a way to have those missing types auto generate from a spec resource definition.
Re: OSLC resource type generator? [message #1765084 is a reply to message #1765026] Tue, 06 June 2017 13:04 Go to previous messageGo to next message
Jim Amsden is currently offline Jim AmsdenFriend
Yes, the eclipse/Lyo Toolchain Modeler and Code Generator can do this.
Re: OSLC resource type generator? [message #1765104 is a reply to message #1765084] Tue, 06 June 2017 15:57 Go to previous messageGo to next message
Member
Great! Thank you!
Re: OSLC resource type generator? [message #1765128 is a reply to message #1765104] Tue, 06 June 2017 21:03 Go to previous messageGo to next message
Jad El-khoury is currently offline Jad El-khouryFriend
Member
Some of the OSLC Domain specs (plus relevant parts of FOAF, dcterms) are already modelled, and can be simply imported and reused within a project.
See tips on this thread https://www.eclipse.org/forums/index.php?t=msg&th=1082140&goto=1759938&#msg_1759938
Re: OSLC resource type generator? [message #1765717 is a reply to message #1765128] Tue, 13 June 2017 20:02 Go to previous messageGo to next message
Member
I'm attempting to install the Lyo Code Generator and Toolchain but Eclipse is having issues. I saw the same warning message for solution 1-3 but the install has been stuck on 4 for the last 3 hours. Any ideas?
http://sws-corp.com/installers/linked/lyo_install.png
Re: OSLC resource type generator? [message #1765723 is a reply to message #1765717] Tue, 13 June 2017 21:09 Go to previous message
Member
I had this same problem today.
Can you check what happens when you press the red square button? You should receive some error message, indicating what conflicts you may have. (In my case, there was a conflict in the versions of Sirius that I happened to have installed).
Can you please share the error message you see?
Previous Topic:Dynamic @OslcDialog property editing?
Next Topic:Update DNG Module Artifact attributes
Current Time: Thu Sep 24 09:30:17 GMT 2020
Powered by FUDForum. Page generated in 0.01947 seconds
