Home » Eclipse Projects » GEF » JavaFX + GEF5: Trouble with display of Pie(The display of a Pie element in a javafx scene seems wrong)
JavaFX + GEF5: Trouble with display of Pie [message #1764542] |
Wed, 31 May 2017 07:01 |
Carsten Meyer Messages: 1 Registered: May 2017 |
I tried to position a GEF5 Pie inside a circle so that the pie's arc matches the circle's arc.
After some experimenting I discovered that the pie's display size does not match it's bounding box as shown below:
The code below creates two test pies (one with a surrounding circle and another without):
package de.simutek.schema.visuals;
import org.eclipse.gef.fx.nodes.GeometryNode;
import org.eclipse.gef.geometry.euclidean.Angle;
import org.eclipse.gef.geometry.planar.Ellipse;
import org.eclipse.gef.geometry.planar.Pie;
import org.eclipse.gef.geometry.planar.PolyBezier;
import org.eclipse.gef.geometry.planar.Rectangle;
import javafx.geometry.Insets;
import javafx.scene.Group;
import javafx.scene.layout.AnchorPane;
import javafx.scene.layout.Background;
import javafx.scene.layout.BackgroundFill;
import javafx.scene.layout.CornerRadii;
import javafx.scene.layout.Region;
import javafx.scene.paint.Color;
public class TestNodeVisual extends Region {
private Group shape;
private Group shape1;
public TestNodeVisual() {
// create background shape
shape = getPumpSymbol();
shape.setTranslateX(50);
shape.setTranslateY(50);
shape1 = getPumpSymbol_1();
shape1.setTranslateX(250);
shape1.setTranslateY(250);
// wrap shape and shape1 in a Group so that their bounds-in-parent is
// considered when determining the layout-bounds of this visual
getChildren().addAll(shape, shape1);
* Create a simple pie.
* Show the bounding boxes by their background color.
private Group getPumpSymbol() {
Pie p = new Pie(0d, 0d, 100d, 100d, Angle.fromDeg(225), Angle.fromDeg(90));
Rectangle rect = p.getBounds();
System.out.println("Pie bounds are : " + rect);
PolyBezier pbz = p.getOutline();
System.out.println("Pie PolyBezier : " + pbz);
GeometryNode<Pie> pTest = new GeometryNode<Pie>(p);
pTest.setPadding(new Insets(0d));
pTest.setBackground(new Background(new BackgroundFill(Color.LIGHTGREEN, CornerRadii.EMPTY, new Insets(0))));
System.out.println("Geom<Pie> bounds: " + pTest.getBoundsInLocal());
AnchorPane box = new AnchorPane();
box.getChildren().addAll(pTest);
box.setBackground(new Background(new BackgroundFill(Color.LIGHTGREY, CornerRadii.EMPTY, new Insets(0))));
return new Group(box);
* Create a simple pie inside a larger circle. Position pie so that
* the arc matches the underlying circle.
private Group getPumpSymbol_1() {
GeometryNode<Ellipse> e = new GeometryNode<Ellipse>( new Ellipse(0d, 0d, 100d, 100d));
e.setPadding(new Insets(0d));
e.setFill(Color.ANTIQUEWHITE);
e.setStroke(Color.BLACK);
e.setStrokeWidth(0.5);
AnchorPane.setLeftAnchor(e, 0d);
AnchorPane.setTopAnchor(e, 0d);
System.out.println("Pie_1 bounds : " + rect);
System.out.println("Pie_1 PolyBezier : " + pbz);
System.out.println("Geom<Pie_1> bounds: " + pTest.getBoundsInLocal());
AnchorPane.setLeftAnchor(pTest, rect.getX());
AnchorPane.setTopAnchor(pTest, rect.getY());
box.getChildren().addAll(e, pTest);
This test visual is the shown in a javafx scene by the following code:
import javafx.application.Application;
import javafx.scene.Scene;
import javafx.scene.layout.Pane;
import javafx.stage.Stage;
public class SchemaVisualApplication extends Application {
Application.launch(args);
public void start(Stage primaryStage) throws Exception {
Pane root = new Pane();
// create state visuals
TestNodeVisual node = new TestNodeVisual();
node.relocate(50, 50);
root.getChildren().addAll(node);
primaryStage.setResizable(true);
primaryStage.setScene(new Scene(root, 1024, 768));
primaryStage.setTitle("This is an JavaFX Environment Test");
primaryStage.sizeToScene();
primaryStage.show();
My tests indicate that from the GEF5 side the pie's bounding box and the pie's PolyBezier curve seem to contain correct data.
Can someone give me a hint wether I'm missing something in my code or wether it's a problem with favafx/gef5.
(The Manifest.mf containing the dependencies is attached to this post.)
Re: JavaFX + GEF5: Trouble with display of Pie [message #1764915 is a reply to message #1764542] |
Sat, 03 June 2017 14:44 |
Hi Carsten,
I can reproduce the issue and am currently looking into it. Feel free to add your findings to the Bugzilla ticket that I created to keep track of the issue [1]. Also, if you find more such errors, please report them at the Bugzilla [2]. Of course, you can always ask for help in the forums first, if you are unsure.
For the time being, you can use the outline of the Pie for rendering:
package my.ba.bezier.offset;
import org.eclipse.gef.geometry.planar.IGeometry;
public class PieSample extends Application {
launch();
Scene scene = new Scene(root, 400, 400);
GeometryNode<IGeometry> ellipse = new GeometryNode<>(new Ellipse(0, 0, 100, 100));
GeometryNode<IGeometry> pie = new GeometryNode<>(new Pie(0, 0, 100, 100, Angle.fromDeg(45), Angle.fromDeg(120)).getOutline());
ellipse.setStroke(Color.TRANSPARENT);
ellipse.setFill(new Color(0.5, 0.5, 0.5, 0.5));
pie.setStroke(Color.TRANSPARENT);
pie.setFill(new Color(1, 0, 0, 0.5));
root.getChildren().addAll(ellipse, pie);
primaryStage.setScene(scene);
Matthias
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=517770
[2] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GEF
[Updated on: Sat, 03 June 2017 15:04] Report message to a moderator
Current Time: Thu Apr 18 05:47:34 GMT 2024
Powered by FUDForum. Page generated in 0.02023 seconds
