Home » Eclipse Projects » JFace » Editing in TreeViewer
Editing in TreeViewer [message #1764459] Tue, 30 May 2017 07:31
Alexander Fichtinger is currently offline Alexander FichtingerFriend
Member
Hey guys! =)
We have a TreeViewer with 4 columns .
The first column displays the name of an object, and the other 3 columns display the configuration for this object.
It looks like this:
NAME | ACTIVE | SEVERITY | TYPE
someObject | true | INFO | someType
anotherObj | false | ERROR | anotherType
Now the problem is this:
If we want to change the severity of "anotherObj" for example we have to click on "anotherObj" first. Then we can change the value of the severity column.
Is this a restriction of the TreeViewer or the SWT tree, that you have to select a row, in order to edit values in it?
Or are we doing something wrong?
Thanks for any help =)
Previous Topic:Custom Control in menu item
Next Topic:How to add custom tooltip to ColumnLabelProvider?
Current Time: Mon Sep 28 00:22:28 GMT 2020
Powered by FUDForum. Page generated in 0.01868 seconds
