Home » Modeling » TMF (Xtext) » Xtext newbie - ID with array declaration
Xtext newbie - ID with array declaration [message #1764364] Mon, 29 May 2017 08:43 Go to next message
Anton Hughes is currently offline Anton HughesFriend
Member
Hello
Im trying to create a dsl that is essentially identical to a simple c++ header file.
I am unsure how to make the following, within the xtext dsl:
   char              myChar[32];
Re: Xtext newbie - ID with array declaration [message #1764365 is a reply to message #1764364] Mon, 29 May 2017 08:46 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
hmmm am not sure if i can follow you
Decl: type=Type name=ID ('[' dim=INT']')?;
enum Type: char | int32| ...;
Twitter : @chrdietrich
Day Job: https://www.everest-systems.com
Re: Xtext newbie - ID with array declaration [message #1764367 is a reply to message #1764365] Mon, 29 May 2017 08:56 Go to previous messageGo to next message
Member
Hi Christian
Apologies for the lack of details.
Dsl
My dsl, currently, looks like this:
struct MyStruct{
	int myInt;
	unsigned int myUnsiggnedInt;
   __time32_t        timestamp;
   char              myChar[32];
Xtext
And my xtext file is:
grammar mydomain.Mydsl with org.eclipse.xtext.common.Terminals
generate Mydsl "http://mydomain/mydsl"
Model:
	structs+=struct*;
struct:
	'struct' name=ID  '{'
		attributes+=Attribute*
Attribute:
	type=AttributeType name=ID ';';
AttributeType:
	elementType=ElementType (array?='[' (length=INT)? ']')?;
ElementType:
	BasicType | StructType;
BasicType:
	typeName=('string' | 'int' | 'boolean'  | 'char' | '__time32_t' |  'unsigned int');
StructType:
	struct=[struct];
Problem
The dsl is currently unable to parse the following line:
   char              myChar[32];
[Updated on: Mon, 29 May 2017 08:57]
Report message to a moderator
Re: Xtext newbie - ID with array declaration [message #1764368 is a reply to message #1764367] Mon, 29 May 2017 09:08 Go to previous messageGo to next message
yes but you put the array to the type, not the name (in the grammar)
[Updated on: Mon, 29 May 2017 09:09]
Re: Xtext newbie - ID with array declaration [message #1764372 is a reply to message #1764368] Mon, 29 May 2017 09:35 Go to previous messageGo to next message
Member
I have tried your suggestion of:
BasicType:
	typeName=('string' | 'int' | 'boolean' | 'double' | 'char' | '__time32_t' |  'unsigned int');
enum Type: char | int32;
But I am still getting an error when I try having the following in the dsl:
char              myChar[32];
Re: Xtext newbie - ID with array declaration [message #1764375 is a reply to message #1764372] Mon, 29 May 2017 09:41 Go to previous messageGo to next message
thats not what i meant
Attribute:
	type=AttributeType name=ID  (array?='[' (length=INT)? ']')? ';';
AttributeType:
ElementType:
BasicType:
	typeName=('string' | 'int' | 'boolean'  | 'char' | '__time32_t' | UINT);
UINT: 'unsigned' 'int';
Re: Xtext newbie - ID with array declaration [message #1764384 is a reply to message #1764375] Mon, 29 May 2017 10:03 Go to previous message
Member
Perfect!
Thanks Christian!
Previous Topic:IFeatureScopeTracker.Provider lsp 2.12
Next Topic:Xtext : shouldgenerate
Current Time: Thu Dec 05 04:57:21 GMT 2024
Powered by FUDForum. Page generated in 0.05296 seconds
