Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Question Generating from XSD(EMF can't read XML that conforms to schema)
Question Generating from XSD [message #1764218] Fri, 26 May 2017 17:42 Go to next message
Geoffry Roberts is currently offline Geoffry RobertsFriend
Member
There must be a workaround for this problem. I would like to what it is.
Mucho thanks to who ever knows this.
I generated an EMF graph from the a schema that contains the following fragment. The fragment shows and element and it's type:
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns="http://standards.ieee.org/IEEE1516-2010" xmlns:ns="http://standards.ieee.org/IEEE1516-2010" targetNamespace="http://standards.ieee.org/IEEE1516-2010" elementFormDefault="qualified" attributeFormDefault="unqualified" version="2010">
<xs:element name="objectModel" type="objectModelType"/>
<xs:complexType name="objectModelType">
<xs:sequence>
<xs:element name="modelIdentification" type="modelIdentificationType" minOccurs="0">
<xs:annotation>
<xs:documentation>documents certain key identifying information within the object model description
</xs:documentation>
</xs:annotation>
</xs:element>
...more xsd...
The generated EMF cannot read the following, valid XML. It fails at the first element shown:
<objectModel xsi:schemaLocation="http://standards.ieee.org/IEEE1516-2010 http://standards.ieee.org/downloads/1516/1516.2-2010/IEEE1516-DIF-2010.xsd" xmlns="http://standards.ieee.org/IEEE1516-2010" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
...more xml...
and yields the following error:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'objectModel' is not found or is abstract. (file:/Users/gcr1/hopeWorkspace/interaction-injection/output/TripleFederation.xml, 2, 252)
Re: Question Generating from XSD [message #1764242 is a reply to message #1764218] Sat, 27 May 2017 06:58 Go to previous messageGo to next message
Did you use the generated resource factory to create the resource that you used to load this XML instance?
Ed Merks
Re: Question Generating from XSD [message #1764408 is a reply to message #1764242] Mon, 29 May 2017 13:48 Go to previous messageGo to next message
Member
No I dd not. I can't do that. I must use documents generated by others, but that conform to the schema I am using to generate.
Re: Question Generating from XSD [message #1764424 is a reply to message #1764408] Mon, 29 May 2017 15:12 Go to previous messageGo to next message
That answer doesn't make sense. You must use the generated resource factory to create the resource that you use to load such an XML instance.
Ed Merks
Re: Question Generating from XSD [message #1764531 is a reply to message #1764424] Wed, 31 May 2017 01:23 Go to previous messageGo to next message
Member
What follows is how I am attempting to load the resource. It works when I load an XML resource that was created and saved using EMF. Do I need something else? I don't see where my generated factory (_2010Factory) comes into the picture.
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xml", new XMLResourceFactoryImpl());
java.net.URI uri = new File(aValidFileName.xml).toURI();
Resource resource = resourceSet.getResource(URI.createURI(uri.toString()), true);
EObject eObject = (EObject) resource.getContents().get(0);
Re: Question Generating from XSD [message #1764540 is a reply to message #1764531] Wed, 31 May 2017 06:44 Go to previous messageGo to next message
If you invoke Generate Test Code in the GenModel it will generate a test project that includes a sample for saving and loading instances. It will be named XyzExample.java, I suppose for you that would be _2010Example.java (given you mention _2010Factory). It looks like this for the LibraryExample.java
  public static void main(String[] args)
    // Create a resource set to hold the resources.
    // Register the appropriate resource factory to handle all file extensions.
      (Resource.Factory.Registry.DEFAULT_EXTENSION,
       new LibraryResourceFactoryImpl());
    // Register the package to ensure it is available during loading.
      (LibraryPackage.eNS_URI,
       LibraryPackage.eINSTANCE);
So I imagine you must have a _2010ResourceFactoryImpl (in the util package of the model project) that you should use and should register your _2010Package.eINSTANCE...
Ed Merks
Re: Question Generating from XSD [message #1764550 is a reply to message #1764540] Wed, 31 May 2017 07:55 Go to previous messageGo to next message
You must also use your _2010ResourceFactoryImpl in
(SOME_EXTENSION,
new _2010ResourceFactoryImpl ());
where SOME_EXTENSION might be Resource.Factory.Registry.DEFAULT_EXTENSION, or "*", or "xml", or "_2010".
I recommend using a distinctive extension, otherwise you will need to delve into the complexities of content types to allow multiple variants of *.xml content.
Ed Willink
Re: Question Generating from XSD [message #1764587 is a reply to message #1764550] Wed, 31 May 2017 13:54 Go to previous messageGo to next message
Member
Ed and Ed,
Thanks for the help so far but I am afraid I am still not out of the woods on this. I added the following to my aforementioned setup as suggested. I am also using the suggested extension. It now looks like this:
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("_2010", new _2010FactoryImpl());
resourceSet.getPackageRegistry().put(_2010Package.eNS_URI, _2010Package.eINSTANCE);
I am now getting an error.
Error:
java.lang.ClassCastException: org.ieee.standards.ieee1516._2010.impl._2010FactoryImpl cannot be cast to org.eclipse.emf.ecore.resource.Resource$Factory
Re: Question Generating from XSD [message #1764588 is a reply to message #1764587] Wed, 31 May 2017 14:20 Go to previous messageGo to next message
Try new _2010ResourceFactoryImpl ()
Re: Question Generating from XSD [message #1764592 is a reply to message #1764588] Wed, 31 May 2017 14:30 Go to previous message
Member
Thank you Ed for your sharp eyes. That little bit got past me.
It is a cosmic truth: "You can't read your own bad writing."
Previous Topic:EMFStore: Is EPackage registration at runtime supported?
Next Topic:How to add a map with generics?
Current Time: Sat May 21 03:07:57 GMT 2022
Powered by FUDForum. Page generated in 0.02012 seconds
