Home » Eclipse Projects » NatTable » A view Issue at NatTable Examples Application on Windows7(Empty view at the right part of the window)
A view Issue at NatTable Examples Application on Windows7 [message #1764167] Fri, 26 May 2017 09:23 Go to next message
Bel Razom is currently offline Bel RazomFriend
NatTable Examples application 1.5.0 has a view issue on Windows 7, Service Pack1.
The right part of the application window is empty for all examples I select. See attachment with a screenshot!
index.php/fa/29457/0/
I've tried the both variants (downloaded today on 26th Mai 2017) with the same issue:
1) JAR
2) Windows x86_64
There are no errors on console, so I have no idea, what's wrong.
My system properties:
java.version=1.8.0_131
OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
I didn't found any bugzilla entry or google results on this issue, so I hope somebody can give some ideas how to fix it.
Re: A view Issue at NatTable Examples Application on Windows7 [message #1764210 is a reply to message #1764167] Fri, 26 May 2017 16:47 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
Maybe a stupid question, but you are trying to open the examples via double click?
I tested the examples on a Windows 7 when we released 1.5. So I wonder why it should be suddenly broken.
Re: A view Issue at NatTable Examples Application on Windows7 [message #1764393 is a reply to message #1764210] Mon, 29 May 2017 11:28 Go to previous messageGo to next message
The JAR was started within a console: java -cp swt.jar;NatTableExamples.jar org.eclipse.nebula.widgets.nattable.examples.NatTableExamples
The Windows EXE started via double click.
Each time I get a window with Examples-Tree on the left side and an empty panel on the right side.
When I click/select any example on the left side nothing happens. The right panel remains empty.
I don't see any errors in a console. So, I have no Idea, what's wrong.
Re: A view Issue at NatTable Examples Application on Windows7 [message #1764411 is a reply to message #1764393] Mon, 29 May 2017 14:09 Go to previous messageGo to next message
Again, do you double click on the left side to open an example or a single click?
Re: A view Issue at NatTable Examples Application on Windows7 [message #1764454 is a reply to message #1764411] Tue, 30 May 2017 05:39 Go to previous messageGo to next message
I just downloaded the examples on a Windows 7 PC and it works as expected. Double click on the example in the tree opens the example on the right.
Re: A view Issue at NatTable Examples Application on Windows7 [message #1764532 is a reply to message #1764454] Wed, 31 May 2017 03:26 Go to previous message
Double click on the left side opens the examples. Thank you.
That was not obvious/intuitive. I didn't see any notice about double click on the right sight or anywhere on your website and I was sure it should work per single click.
Previous Topic:Multiple Selection in NatTable
Next Topic:Unavailable dependencies in the Getting Started Tutorial
Current Time: Thu Apr 25 05:09:10 GMT 2024
Powered by FUDForum. Page generated in 0.03343 seconds
