resolution of uriFragment '|0' failed. [message #1764137] |
Thu, 25 May 2017 18:56 |
Fy Za Messages: 245 Registered: March 2010 |
I have this grammar
grammar org.xtext.example.mydsl3.FSM with org.eclipse.xtext.common.Terminals
generate fSM "http://www.xtext.org/example/mydsl3/FSM"
Model:
types+=EnumerationType*
fsm+=FSM*
FSM:
'FSM'
'type' type=[EnumerationType|QualifiedID]
ownedState+=State*
State:
'State'
('literal' literal=[EnumerationLiteral|QualifiedID])
('transitions' '(' (outgoingTransition+=Transition)* ')')?
Transition returns Transition:
'to' target=[State|QualifiedID]
EnumerationType:
'EnumerationType'
name=ID
'literals'
literals+=EnumerationLiteral ( "," literals+=EnumerationLiteral)*
EnumerationLiteral:
name=ID
QualifiedID : (ID | QUALIFIED_ID ) ;
terminal QUALIFIED_ID :
'^'?('a'..'z'|'A'..'Z'|'_')('a'..'z'|'A'..'Z'|'_'|'0'..'9')* '.' ('a'..'z'|'A'..'Z'|'_')('a'..'z'|'A'..'Z'|'_'|'0'..'9')* ( '.' ('a'..'z'|'A'..'Z'|'_')('a'..'z'|'A'..'Z'|'_'|'0'..'9')* )*;
It allows to create model like this one
EnumerationType enum1 literals ( literal1 , literal2 )
FSM {
type enum1
State
literal enum1.literal1
transitions ( to enum1.literal2 )
State
{ literal enum1.literal2
transitions ( to enum1.literal1 )
At this stage, I have errors on transitions (Couldn't resolve reference to State 'enum1.literal2'.) because scope management are not completed.
I add the required scope management as shown in the following
class FSMScopeProvider extends AbstractFSMScopeProvider {
override getScope(EObject object, EReference ref) {
if (object instanceof Transition) {
scope_Transition_target(object as Transition, ref)
def scope_Transition_target(Transition transition, EReference reference) {
var ArrayList<IEObjectDescription> res = new ArrayList<IEObjectDescription>
var State s = transition.eContainer as State
var FSM fsm = s.eContainer as FSM
for (state : fsm.ownedState) {
res.add(
EObjectDescription.create(
QualifiedName.create((state.literal.eContainer as EnumerationType).name, state.literal.name),
state.literal))
// println("res " + res)
return new SimpleScope(IScope.NULLSCOPE, res)
However, when I edit my model an error wizard appears
and additional errors appear in the console as shown in below.
Any suggestion?
If there are any who may be interested to reproduce,
the source code is available here https://github.com/fzalila/xtextfsm/tree/master/org.xtext.example.mydsl3
and an example project is available here https://github.com/fzalila/xtextfsm/tree/master/fsm-example
best regards
327718 [Worker-13] ERROR org.eclipse.xtext.linking.lazy.LazyLinkingResource - resolution of uriFragment '|0' failed.
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:122)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:247)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:222)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doResolveLazyCrossReference(LazyLinkingResource.java:189)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReference(LazyLinkingResource.java:148)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReferences(LazyLinkingResource.java:134)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:498)
at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.postParse(XtextDocumentReconcileStrategy.java:175)
at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.doReconcile(XtextDocumentReconcileStrategy.java:153)
at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.reconcile(XtextDocumentReconcileStrategy.java:67)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.doRun(XtextReconciler.java:449)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.access$3(XtextReconciler.java:429)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler$1.process(XtextReconciler.java:363)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler$1.process(XtextReconciler.java:1)
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:37)
at org.eclipse.xtext.resource.OutdatedStateManager.exec(OutdatedStateManager.java:91)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.modify(XtextDocument.java:428)
at org.eclipse.xtext.ui.editor.model.XtextDocument.internalModify(XtextDocument.java:162)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.run(XtextReconciler.java:360)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:07.553
!MESSAGE org.eclipse.xtext.linking.lazy.LazyLinkingResource - resolution of uriFragment '|0' failed.
!STACK 0
327719 [Worker-13] ERROR org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy - Error post-processing resource with content:
EnumerationType tt literals ( aa , bb )
FSM {
type tt
State
literal tt.aa
transitions ( to tt.bb )
State
{ literal tt.bb
transitions ( to tt.aa )
org.eclipse.emf.common.util.WrappedException: java.lang.NullPointerException
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:230)
... 17 more
!MESSAGE org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy - Error post-processing resource with content:
FSM {
type tt
State
literal tt.aa
State
{ literal tt.bb
!STACK 0
... 17 more
327723 [Worker-13] ERROR org.eclipse.xtext.linking.lazy.LazyLinkingResource - resolution of uriFragment '|0' failed.
at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:161)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:74)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:91)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:1)
at org.eclipse.xtext.util.concurrent.CancelableUnitOfWork.exec(CancelableUnitOfWork.java:26)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.internalReadOnly(XtextDocument.java:520)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.readOnly(XtextDocument.java:492)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:133)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.createIssues(ValidationJob.java:86)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.run(ValidationJob.java:67)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:07.557
!STACK 0
327724 [Worker-13] ERROR org.eclipse.xtext.ui.editor.validation.ValidationJob - Error running validator
... 16 more
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:07.558
!MESSAGE org.eclipse.xtext.ui.editor.validation.ValidationJob - Error running validator
!STACK 0
... 16 more
328374 [Worker-13] ERROR org.eclipse.xtext.linking.lazy.LazyLinkingResource - resolution of uriFragment '|0' failed.
at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:230)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.update(AbstractBuilderState.java:116)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:287)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:267)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:161)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:735)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:301)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:304)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:360)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:383)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:144)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:235)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.208
!STACK 0
328374 [Worker-13] ERROR org.eclipse.xtext.builder.clustering.ClusteringBuilderState - Error loading resource from: platform:/resource/test/My.fsm
... 21 more
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.209
!MESSAGE org.eclipse.xtext.builder.clustering.ClusteringBuilderState - Error loading resource from: platform:/resource/test/My.fsm
!STACK 0
... 21 more
328376 [Worker-13] ERROR org.eclipse.xtext.builder.clustering.CopiedResourceDescription - java.lang.IllegalStateException: getReferenceDescriptions platform:/resource/test/My.fsm
at org.eclipse.xtext.builder.clustering.CopiedResourceDescription.getReferenceDescriptions(CopiedResourceDescription.java:84)
at org.eclipse.xtext.builder.builderState.BuilderStateUtil.copyReferenceDescriptions(BuilderStateUtil.java:59)
at org.eclipse.xtext.builder.builderState.BuilderStateUtil.create(BuilderStateUtil.java:34)
at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:267)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.210
!MESSAGE org.eclipse.xtext.builder.clustering.CopiedResourceDescription - java.lang.IllegalStateException: getReferenceDescriptions platform:/resource/test/My.fsm
!STACK 0
328377 [Worker-13] ERROR org.eclipse.xtext.builder.clustering.CopiedResourceDescription - java.lang.IllegalStateException: getImportedNames platform:/resource/test/My.fsm
at org.eclipse.xtext.builder.clustering.CopiedResourceDescription.getImportedNames(CopiedResourceDescription.java:75)
at org.eclipse.xtext.builder.builderState.BuilderStateUtil.copyImportedNames(BuilderStateUtil.java:40)
at org.eclipse.xtext.builder.builderState.BuilderStateUtil.create(BuilderStateUtil.java:35)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.211
!MESSAGE org.eclipse.xtext.builder.clustering.CopiedResourceDescription - java.lang.IllegalStateException: getImportedNames platform:/resource/test/My.fsm
!STACK 0
328380 [Worker-13] ERROR org.eclipse.xtext.linking.lazy.LazyLinkingResource - resolution of uriFragment '|0' failed.
at org.eclipse.xtext.ui.validation.DefaultResourceUIValidatorExtension.addMarkers(DefaultResourceUIValidatorExtension.java:60)
at org.eclipse.xtext.ui.validation.DefaultResourceUIValidatorExtension.updateValidationMarkers(DefaultResourceUIValidatorExtension.java:46)
at org.eclipse.xtext.builder.builderState.MarkerUpdaterImpl.processDelta(MarkerUpdaterImpl.java:93)
at org.eclipse.xtext.builder.builderState.MarkerUpdaterImpl.updateMarkers(MarkerUpdaterImpl.java:63)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.updateMarkers(AbstractBuilderState.java:82)
at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:283)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.214
!STACK 0
328380 [Worker-13] ERROR org.eclipse.xtext.builder.clustering.ClusteringBuilderState - Error validating platform:/resource/test/My.fsm
... 28 more
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.215
!MESSAGE org.eclipse.xtext.builder.clustering.ClusteringBuilderState - Error validating platform:/resource/test/My.fsm
!STACK 0
... 28 more
328882 [Worker-13] ERROR org.eclipse.xtext.linking.lazy.LazyLinkingResource - resolution of uriFragment '|0' failed.
at org.eclipse.xtext.resource.impl.DefaultResourceDescription.computeReferenceDescriptions(DefaultResourceDescription.java:135)
at org.eclipse.xtext.resource.impl.DefaultResourceDescription$2.get(DefaultResourceDescription.java:123)
at org.eclipse.xtext.resource.impl.DefaultResourceDescription$2.get(DefaultResourceDescription.java:120)
at org.eclipse.xtext.util.OnChangeEvictingCache.get(OnChangeEvictingCache.java:77)
at org.eclipse.xtext.resource.impl.DefaultResourceDescription.getReferenceDescriptions(DefaultResourceDescription.java:120)
at org.eclipse.xtext.resource.DescriptionUtils.collectOutgoingReferences(DescriptionUtils.java:29)
at org.eclipse.xtext.resource.impl.DefaultResourceDescriptionManager.isAffected(DefaultResourceDescriptionManager.java:117)
at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport.isReparseRequired(DirtyStateEditorSupport.java:649)
at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport$UpdateEditorStateJob$1.exec(DirtyStateEditorSupport.java:161)
at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport$UpdateEditorStateJob$1.exec(DirtyStateEditorSupport.java:1)
at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport$UpdateEditorStateJob.run(DirtyStateEditorSupport.java:146)
!ENTRY org.apache.log4j 4 0 2017-05-25 20:31:08.716
!STACK 0
!ENTRY org.eclipse.xtext.ui 4 0 2017-05-25 20:31:08.717
!MESSAGE Error updating dirty state editor
!STACK 0
... 20 more
Attachment: xtextfsm.png
(Size: 157.93KB, Downloaded 1476 times)
Re: resolution of uriFragment '|0' failed. [message #1764140 is a reply to message #1764139] |
Thu, 25 May 2017 19:23 |
Thanks Christian
I update my scope class
* generated by Xtext 2.11.0
package org.xtext.example.mydsl3.scoping
import org.eclipse.emf.ecore.EObject
import org.eclipse.emf.ecore.EReference
import org.xtext.example.mydsl3.fSM.Transition
import java.util.ArrayList
import org.eclipse.xtext.resource.IEObjectDescription
import org.xtext.example.mydsl3.fSM.State
import org.xtext.example.mydsl3.fSM.FSM
import org.eclipse.xtext.resource.EObjectDescription
import org.eclipse.xtext.naming.QualifiedName
import org.xtext.example.mydsl3.fSM.EnumerationType
import org.eclipse.xtext.scoping.impl.SimpleScope
import org.eclipse.xtext.scoping.IScope
* This class contains custom scoping description.
* See https://www.eclipse.org/Xtext/documentation/303_runtime_concepts.html#scoping
* on how and when to use it.
else{
super.getScope(object, ref)
res.add(
state.literal))
However errors on transitions (Couldn't resolve reference to State 'enum1.literal2'.) reappear as shown in the image
the strange thing is that the editor proposes 2 quick fixes.
It couldn't resolve reference to State 'enum1.literal1' on the hand, and proposes quick fixes containing one of provided element ('enum1.literal1') on the other hand.
Is it normal?
Attachment: xtextfsm2.png
(Size: 524.61KB, Downloaded 1705 times)
[Updated on: Thu, 25 May 2017 19:33] Report message to a moderator
Re: resolution of uriFragment '|0' failed. [message #1764200 is a reply to message #1764147] |
Fri, 26 May 2017 15:20 |
Thank you Christian for the suggestion.
I understand how linking and scoping mechanisms work.
The second edition of Lorenzo Bettini book explains how both mechanisms interact.
I create a FSMLinkingService class and I override the getLinkedObjects method (as you suggest) as shown below
public class FSMLinkingService extends DefaultLinkingService {
private static final Logger logger = Logger.getLogger(DefaultLinkingService.class);
@Inject
private IQualifiedNameConverter qualifiedNameConverter;
public List<EObject> getLinkedObjects(EObject context, EReference ref, INode node) throws IllegalNodeException {
final EClass requiredType = ref.getEReferenceType();
if (requiredType == null) {
return Collections.<EObject>emptyList();
final String crossRefString = getCrossRefNodeAsString(node);
if (crossRefString == null || crossRefString.equals("")) {
if (logger.isDebugEnabled()) {
logger.debug("before getLinkedObjects: node: '" + crossRefString + "'");
final IScope scope = getScope(context, ref);
final QualifiedName qualifiedLinkName = qualifiedNameConverter.toQualifiedName(crossRefString);
final IEObjectDescription eObjectDescription = scope.getSingleElement(qualifiedLinkName);
logger.debug("after getLinkedObjects: node: '" + crossRefString + "' result: " + eObjectDescription);
if (eObjectDescription == null) {
return Collections.emptyList();
final EObject result;
if (context instanceof Transition && ref.getName().equals("target")) {
State state = getReferringState((EnumerationLiteral) eObjectDescription.getEObjectOrProxy());
result = state;
} else {
result = eObjectDescription.getEObjectOrProxy();
return Collections.singletonList(result);
private State getReferringState(EnumerationLiteral literal) {
EnumerationType type = (EnumerationType) literal.eContainer();
Model model = (Model) type.eContainer();
for (FSM fsm : model.getFsm()) {
for (State state : fsm.getOwnedState()) {
if (state.getLiteral() == literal)
return state;
return null;
And now, the errors resolved.
However the xmi output of the following parsingTest doesn't resolve references
def void loadModel() {
EPackage.Registry.INSTANCE.put(FSMPackage.eNS_URI, FSMPackage::eINSTANCE)
val result = parseHelper.parse('''
FSM {
type enum1
State
State
Assert.assertNotNull(result)
Assert.assertTrue(result.eResource.errors.isEmpty)
RS2 = new ResourceSetImpl
val r2 = RS2.createResource(URI.createURI("dummy.xmi"))
r2.contents.add(result)
val baos = new ByteArrayOutputStream
r2.save(baos, null)
println(new String(baos.toByteArray, StandardCharsets.UTF_8))
It generates the following xmi that doesn't resolve the reference to states (target reference <target href="__synthetic0.fsm#|2"/> ) and literals (<literal href="__synthetic0.fsm#|1"/>)
How can resolve this please?
best regards,
<?xml version="1.0" encoding="ASCII"?>
<fSM:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:fSM="http://www.xtext.org/example/mydsl3/FSM">
<types name="enum1">
<literals name="literal1"/>
<literals name="literal2"/>
</types>
<fsm type="//@types.0">
<ownedState>
<outgoingTransition>
</outgoingTransition>
</ownedState>
<ownedState>
<literal href="__synthetic0.fsm#|3"/>
<target href="__synthetic0.fsm#|4"/>
</ownedState>
</fsm>
</fSM:Model>
Re: resolution of uriFragment '|0' failed. [message #1764208 is a reply to message #1764206] |
Fri, 26 May 2017 16:28 |
when I add ecoreUtil2.resolve all , the "resolution of uriFragment '|0' failed" error reappears
0 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|0' failed.
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at java.util.ArrayList.rangeCheck(ArrayList.java:653)
at java.util.ArrayList.get(ArrayList.java:429)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.hasLazyProxyInformation(LazyLinkingResource.java:502)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getLazyProxyInformation(LazyLinkingResource.java:509)
at org.eclipse.xtext.linking.lazy.LazyURIEncoder.getLazyProxyInformation(LazyURIEncoder.java:148)
at org.eclipse.xtext.linking.lazy.LazyURIEncoder.decode(LazyURIEncoder.java:127)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:221)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:203)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:259)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1477)
at org.xtext.example.mydsl3.fSM.impl.FSMImpl.getType(FSMImpl.java:94)
at org.xtext.example.mydsl3.fSM.impl.FSMImpl.eGet(FSMImpl.java:168)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1011)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1003)
at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.hasNext(EContentsEList.java:439)
at org.eclipse.emf.ecore.util.EcoreUtil.resolveCrossReferences(EcoreUtil.java:304)
at org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(EcoreUtil.java:298)
at org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(EcoreUtil.java:283)
at org.xtext.example.mydsl3.tests.FSMParsingTest.loadModel(FSMParsingTest.java:82)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
at org.eclipse.xtext.testing.XtextRunner$1.evaluate(XtextRunner.java:49)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:678)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
4 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|1' failed.
java.lang.IndexOutOfBoundsException: Index: 1, Size: 0
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:199)
at org.xtext.example.mydsl3.fSM.impl.StateImpl.getLiteral(StateImpl.java:94)
at org.xtext.example.mydsl3.fSM.impl.StateImpl.eGet(StateImpl.java:168)
6 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|1' failed.
8 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|2' failed.
java.lang.IndexOutOfBoundsException: Index: 2, Size: 0
at org.xtext.example.mydsl3.fSM.impl.TransitionImpl.getTarget(TransitionImpl.java:74)
at org.xtext.example.mydsl3.fSM.impl.TransitionImpl.eGet(TransitionImpl.java:118)
9 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|2' failed.
10 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|3' failed.
java.lang.IndexOutOfBoundsException: Index: 3, Size: 0
11 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|4' failed.
java.lang.IndexOutOfBoundsException: Index: 4, Size: 0
12 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|4' failed.
Re: resolution of uriFragment '|0' failed. [message #1764220 is a reply to message #1764211] |
Fri, 26 May 2017 18:03 |
well i had a look with my parents pc.
in your test you miss a
EcoreUtil.resolveAll(result.eResource.resourceSet)
besides this i dont get any errors in the editor nor in the test (using xtext 2.12)
if i revert the changes to linking service i get the error you describe
and the cause is clear
QualifiedName.create((state.literal.eContainer as EnumerationType).name, state.literal.name), state.literal))
you add literals to the scope. not states
you may want to do a
QualifiedName.create((state.literal.eContainer as EnumerationType).name, state.literal.name), state))
instead
Twitter : @chrdietrich
Re: resolution of uriFragment '|0' failed. [message #1764221 is a reply to message #1764220] |
Fri, 26 May 2017 18:19 |
Sorry Christian for this trivial error. Yes it must be state and not state.literal.
I add testCorrectParsing test (ValidationTestHelper).
class FSMParsingTest {
@Inject extension ParseHelper<Model> parseHelper
@Inject extension ValidationTestHelper
@Test
def void testCorrectParsing() {
FSM {
type enum1
State
State
'''.parse.assertNoErrors
@Test
FSM {
type enum1
State
State
val RS2 = new ResourceSetImpl
// added resolve
r2.save(baos, null)
Both tests testCorrectParsing and loadmodel are correct.
However, despite the add of EcoreUtil.resolveAll(result.eResource.resourceSet) the generated xmi is always doesn't contain the resolved references
</types>
<fsm>
<type href="__synthetic0.fsm#|0"/>
<ownedState>
</ownedState>
<ownedState>
</ownedState>
</fsm>
</fSM:Model>
and this error is always here during loadModel test
1 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|0' failed.
at org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(EcoreUtil.java:271)
at org.xtext.example.mydsl3.tests.FSMParsingTest.loadModel(FSMParsingTest.java:134)
5 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|1' failed.
7 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|2' failed.
8 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|3' failed.
9 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|3' failed.
10 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|4' failed.
FUDForum. Page generated in 0.04495 seconds
